Cayenne S alarm LED in door card.
Hi all another question after i arm the alarm on my Cayenne S the LED on the door card flashes as it should then stops............. checked in the manual and it says that it should then flash at a slower rate any idea what this slower rate? once every 5 mins or 10 mins? reason i ask it would appear that mine is not flashing at that rate as i have stood by the car for over 5mins and nothing after it is armed and done its thing when it is first locked
again any help and guidance is appreciated![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Craig
Craig
I purchased three used ones and tried them all - even cut one open to see if it had the bad battery issue. All of them did not fix the problem Flashers blink when you lock and walk away
Is there a different Alarm module that needs replacing ?
Do these modules need to be coded?
Can you take one from an audi or VW - same part numbers and try those as well without any coding required ?
My 09 GTS is doing the same thing. Have a replacement Alarm module ready to go in next week. Interested in your resolution.
What were the part numbers for the modules you tried? There have been several updates since the original 957 unit, and my research indicates all should still work.
mine is blinkning okay for say a day, but the next day it can stop blinking at all.
sometime is stops blinking after a couple of hours. have no idea what's wrong and is it a real issue.
