Cayenne Turbo S Front Rotors?
Not so strange is that the discs (I am refering to 996/986S at the moment) are made in China.
Yea, if it is too cheap to believe, it is usually Chinese. The Chinese brake rotors have given many people problems with premature warping and such. The Cast Iron is subpar and pourous.
Quick update, I have been told the SHW made Cayenne Turbo S front rotors may be available through TextarOE line in September, should be about $400 each, so worth waiting!!
Not changed yet, waiting for the Textar/SHW ones to show up, hopefully in the next 3 months they will be available, I reckon I have another years worth on the originals.
Resurrecting this thread, wish I'd found it a couple days ago before starting another. I will have about 70,000 miles at the time of the brake service I"m anticipating late this year. I'm definitely going to need rotors, pads, tires at that time. My question this time is on calipers. Recommend replacement? I can only assume mine are original, have had the car since 40k miles. Should I swap them out? I want to change the color anyway from red to yellow, so I'm already in for $150 a piece doing that. If new can be ordered in yellow, makes it easier to pull the trigger. Thoughts? TIA
