Handling improvement priorities and recommendations...
#31
Just call me Pops
I think we need for a third person to chime in, so that I'd know who's right/wrong here.
Comrade, буду болеть за вас, but let the right man be right
#32
#33
Spasibo bolshoe Chushka, we've established that the diameter doesen't change so a 5" cylinder 10" long has a volume of 196 in3 and a 5" cylinder 14" long has a volume of 275 in3, doesn't really stretch the intellect too far.
#34
The folds in the bottom part of the air bag allows it to extend and retract.
Porsche didn't invent something new here, I hate to break it to you.
#35
![](https://media.caranddriver.com/images/media/268747/2010-porsche-panamera-air-suspension-cutaway-photo-268777-s-520x318.jpg)
Air bag isn't rigid, therefore, it contains the same volume (to some degree, since the bag will also expand slightly at max pressure) depending on ride height. When pressure increases, the bag inflates and height increases.
Anyway, that's all folks. Believe it or not. Engineer or not so engineer.
#37
Admin
The Cayenne features a closed air suspension system with a compressor, solenoid block with integrated pressure sensor and a pressure accumulator. To raise the vehicle, air is pumped into the spring units by the electric compressor. When lowering the vehicle, the excess air is not released to the outside, but is fed back into the 5.2-litre pressure accumulator by the compressor.
Raising
The air springs on the front and rear axles are filled separately in order to raise the vehicle. Air is pumped out of the accumulator by the compressor and is routed to the air springs via pipes and valves. Change-over valve 1 and the corresponding airspring change-over valves (e.g. USV) are switched for this purpose.
Lowering
The air springs on the front and rear axles are switched separately in order to lower the vehicle. Air is pumped out of the air spring by the compressor via change-over valve 1. The air is routed through the air drier and change-over valve 2 into the accumulator. This circuit design means that any moisture is repeatedly eliminated from the system.
Raising
Lowering
#39
Thanks, John, this is my point. It's the "basic" concept of a pneumatic suspension system - not just Porsche's. I've described the above in my prior post as well.
My point is ride height is controlled by pressure changes, which is what I've described multiple posts prior also. This is again consistent with what is in your post.
#42
I don't believe anyone mentioned Porsche inventing air suspension
Nice piccie but not very informative.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Raising
Lowering
Raising
Lowering
Another little question for you to ponder over, how does an airspring achieve its progressive spring rate without changing volume? .......Beats me
Until now I hadn't actually researched anything I'd written as it all seemed pretty obvious, but since you wouldn't believe me I did a little research and wonder if you will now believe Firestone. Below a couple of extracts from the Firstone design guide for the particular type of spring (rolling bellows) we have, for the main part, been discussing.
The full PDF can be found here
The first pic shows that for the recommended operating range between heights of 20 and 16 inches the following statements are true:
1. At a given pressure the load rating is constant
2. In shortening the spring from 20" to 16" the volume decreases from 1351.3 in3 to 1058.06 in3
The second pic shows that:
1. The spring rate is higher at a higher pressure.
2. For any given pressure, the spring rate is highest at the lowest ride height.
This is the basic principle of most air springs fitted to cars.
