2004 Cayenne Turbo Driveline bearing
Hello....has anyone had experience replacing the bearing?
I was wondering if i have to destroy the bellows to remove the forward end of the cv joint.
Or is there another way?
Thanks in advance
chris von ravensberg
2004 TT
Thanks in advance
2004 TT
If you search cardan shaft you will find a few write-ups on how to replace just the center bearing. All the write-ups contain the phrase cardan shaft since the bearing is attached to the shaft...
