Snow chains on 958
I picked up my cayenne on Sunday and among the many, many forms to sign was one that stated snow chains might not work on the car and if I used them I was solely responsible for what happened. I drive up into the Sierra several times during the winter and there are plenty of times when chains are required for most vehicles. So I have 2 questions:
1) when snow chains are required, does the Cayenne get a pass (some 4x4s like Jeeps do). I'm guessing no. I suspect the cayenne is capable enough but doubt the police would let me by without them.
2) can you put snow chains on an 18" wheel? If so, any advice on where to buy?
Rocky Mountain High
I'm not entirely sure for the 958, but for the 955/957 there are snow chain options offered by Porsche. I would imagine that's true for the 958 also, but I'm not sure. Your dealer's service department or parts department should be able to help you.
Where I live, if you've got an AWD or 4WD vehicle and you've got proper winter tires in place (designated by the snowflake on the mountain symbol), then you aren't required to put chains on. Check your local laws, but I would imagine that the same applies to you.
California has 3 levels of control on the highways during snow conditions. The first (and most common) is "chains or snow tires" which is obvious. The second is "chains or 4WD with all 4 snow tires" If your Cayenne has tires marked "M+S" as do the Michelin Latitude Tour All Season, then you are good to go here. When the 3rd level is reached, we should all turn around and go home.
U should get a dedicated set of snow tires/wheels. Awd on the pepper mite go on the fritz and if they snap off will destroy a few sensors in the process plus it's loud- ask me how I know : (. Mike
Dedicated snow tires don't really make sense for me. I am in Tahoe for a few days a month but mostly in snow free San Francisco. I do have all season tires and am guessing they are fine for everything but mountain passes. If CHP would let the AWD SUVs' pass then I am good.
I see I can get Porsche chains for 400 at sun coast but others are saying a 90 set from autoparts store is fine. A little worried about putting cheap ones on my new cayenne though.
Just to let u know I was caught in a snowstorm heading over donner pass(scary)running all season tires. Day after I could not even get out of the driveway and once I did I was sliding down the road(I had to hit snowbank from snowbank just to stop). Got to the nearest gas station and got cables- it did not help at all. It was tolerable going straight but ne turns or braking car would snap. Also on the way- part of cable snapped off and started wreaking havoc to the point as I said destroyed some sensors on both rt/lft front ie abs/Psm. Took it to dealer and $1500 later- I will never put chains on the pepper. Prior season I had snow tires it was effortless. Just want u to avoid what happened to me. Mike
There are some expensive clamp on type chains that I have when it is really deep. Got them at Les Schwab and they work with the 18" tires quite well. That reminds me I have 19's now and don't know if they will fit the new rims.
If you have dedicated studless tires, they are no problem. Studs I am not sure in California. Oregon they are allowed Nov 1- Apr-1. I have not used studs since studless tires came out.
Tex94: You can drive around in snow tires all year round if you like. I believe you are thinking studded tires.
On my wifes car we have Blizzaks (or how ever its spelled). Better snow traction and much quiter.
One snow tire I REALLY liked (and it was cheap) was Copper snow tires. Amazing grip. Just not sure if they come in cayenne sizes. I know they come in 17" as I still have an unmounted set in my basement.
Even on vehciles that I have all terrian tires, I like snow tires in the winter. They just seem to work better.
-Dana
