08 TT
Honestly, I don't have ANY personal experience here, just what I've read here/online and heard from independent mechanics that I know are competent and have no 'vested' interest. The problem seems to be prevalent enough that Porsche had to issue dealer TSB type 'direction' to their people on how to determine what/if they were liable for repair costs wise and the coatings the factory uses and materials for the cylinder sleeving and piston rings have changed on newer engines as a result .. and that includes all of their model lines .. Turbo's seem to be more susceptible because of the increased temperatures/forces inside those engines and on this forum, I've read theories that ambient environmental temperatures (mountain/snow v.s. coastal/desert) and conditions might be a factor .. Not knowing the actual numbers of failures, and I'm sure Porsche wouldn't give out that information readily .. , it's very difficult to say what the percentage of engines experience this are .. and if the second generation 4.8V8 from '08 and on really is still a 'problem' ... I do know of a few 997, Cayman and next gen Boxster engines that have failed due to soft cylinder sleeves ... but again, the percentage is unknown to me.
I know of the M96 soft cylinder sleeves. LN Engineering seems to have a good solution with their nickies sleeves. It would be interesting to know if LN or another company are working on similar re-sleeving for the V8 motors - it could be a good (if not superior) alternative to an entire short block.
I am the last post .. but the link is one or two posts before me. Interesting information but inconclusive really ..
Moderator !x4
Engine sounds great, plenty of power. No extraneous noises, and little or no oil between changes. Computer tells me to change more frequently now.
Tx is good but it's an 05, was swapped early under warranty . Some noise from transfer case and front diff was resolved by dealer tighning up and changing oil
Apart from brakes/ rotors / tires it's trouble free, the person who gets it is in for a treat. Coils.coolant pipes,Carden shaft, both front air struts, compressor all taken care of. By tomorrow right fuel pump and next weekend left fuel pump
Insanity rules
I love this car, fits me like glove
Insanity rules
I still say you've pretty much 'beat the house' here with 129K miles. Is there anyone else on the forum with higher mileage that's only replaced the 'usual suspects'? ....
It's sad when 129k is considered "high mileage" for a modern motor. My old M113 V8 motor in my E430 has 187k and still idles smooth and runs strong. (Sorry for going off topic)
I think a 957 CTT would be perfect, esp. if they have "improved" on the past designs, however, there doesn't seem to be any signs of "improvement," mechanically.
I've been looking for a 957 CTT to replace the X5 but now... I don't know.
Moderator !x4
I don't consider it way high, but we all have a comfort zone. This is my daily ride and is needed to function all the time. However I still might decide to stay with her
