First little problem.. wet carpet
So one week down the line and found a wet patch on the passenger side under the mat. Stripped off the passenger plastic wheel arch off this morning to clear any debris from the sunroof drain, tested and now flowing freely.
The carpet was wet around the feet area not the upper backing so this may fix it, guess it could be a condenser drip so will check that out if it persists.
Just call me Pops
Wet carpet. Hm.
My P!G never had problems with wet carpet, but I'm positive someone will have experience in that area, but it definitely won't be Divot
My rear drivers side grab handle usually gets damp during a heavy rain fall. Sitting through this hurricane it was soaked and heavily dripping on my rear seat. I don't understand the whole sunroof drain holes. Could someone please explain. I stood on my seat and there are 2 holes on the sunroof surround but they seem clear
Caesar
Caesar
The V8 Porschephile
Beware of a wet carpet and an eventual corroded wiring connector underneath the carpet. PAG/VAG's bright engineers decided to mount an electrical connector at the lowest point of the footwell where water can collect. This in turn results in a corroded wiring connector which when wet or weak can wreak havoc on the CAN bus network and can prevent your Cayenne from starting and/or cause numerous electrical gremlins. Ask me how I know this....
Same thing happened on my '08 S. The A/C unit drain got blocked (tube my have collapsed, I'm not sure) and flooded the driver and passenger side footwells. There was a ridiculous amount of water. While the dealer was repairing it, the wiring harness failed and the car wouldn't start. They repaired everything under warranty fortunately. No problems since.
Discovered water this am on the passenger's side flor. Lots of it!! The car smelled like hell! Funny thing is that last week I steam cleaned the carpet. Murphy's law I guess?? Not sure where to start yet but I have a trip to Miami planned tonight. Hope it doesnt rain. I did flush the drain tube with my hose last w/end. Does anyone know if I may have twisted or collapsed something unintentionally. All I did was pull the rubber off the tube to insert the hose and replaced the cabin filter.
Much missed
Wet vac out as much as you can get from the carpet. Remove floor mats to dry. Leave windows down with a fan on the carpet.
The dealer tracked mine down to a disconnected sun roof drain tube. It ran to the rear passenger grab handle as well as my subwoofer in the rear killing it as well. Covered under cpo
Before I finished reading your entire posting, the thought went through my mind; how does this guy know so much about these cars!?!?! I've seen several of your posts, and this isn't the first time you've had deep knowledge on the subject.
Very easy to access and clean. It is located on the passenger side firewall. Remove the trim panel under the glove compartment and disconnect the plugs. You will see the drain hose at the bottom of the fan case. Have a cup under the hose just incase some water is in there. Good luck.
Hello guys and girls. When you
say "connector" which one do you mean? I did have the dreaded lagoon in my passenger side. Im talking gallons! This is about 3 or 4 years ago. Tried to dry everything with hot air as much as I could before putting everything back together which took me 3 weeks to dry. I tried to "supper wrap" everything but now Im thinking that maybe that worked against me by allowing some condensation to be trapped? Reason is that tonight I got a few gremlins on the dash: flashing red BRAKE light, BRAKE PROPORTIONING in red, ABS light on, speedometer quit and cruise control doesn't work. All at the same time WTF??? Also got some codes with DURAMETRIC: 1316 PSM control module, 459 (which I think you get when you put an after market radio), 1299 Gateway, P1630 CAN timeout - TCS/EDTC and 1592 Air quality sensor. I disconnected the battery for a few hrs since DURAMETRIC did not erase the faults and nothing changed. I pulled the carpet on the driver's side and the cables seemed fine at least from where the tape ends (coming from the upper dashboard area) to the junction box near the battery. Im at a dead end here. Can someone suggest where to go from here please?
