Changed the Differential Oil and Transfer Case Oil Fluid
#31
That is a good price for the Aisin tranny fluid. If you buy it get the ATF0T4. I am sticking with my Redline D4 as it is a full synthetic but if you want the OEM fluid looks like AutohausAZ is the ticket.
#32
Hey Guys,
When you say you are using "Mobil 1 Synthetic" shouldn't it be Mobil ATF 3309? The 3309 is the oil for Aisin Transmissions
Mobil 1 Synthetic,
http://www.mobiloil.com/USA-English/...etic_ATF.aspx#
Mobil ATF 3309,
http://www.mobiloil.com/USA-English/...ATF_3309.aspx#
Mobil 1 Synthetic,
Mobil ATF 3309,
#34
#37
Some more info related to this excellent thread. Thanks for sharing.
http://www.6speedonline.com/forums/c...mendation.html
#38
They are dropping the pan and changing the filter and gasket.
Alot of people are going with Mobil 1 atf, I would go with Aisin http://www.autohausaz.com/search/pro...smission Fluid
And use maeyle filter and pan gasket. Differentials would get Liqui Moly gear oil: http://www.autohausaz.com/search/pro...fferential Oil
I swapped out my valve body and did a fluid change using redline but there are subtle cues it's not perfect. I'm going to do 2 changes to try getting back to all Aisin fluid. I'm wondering if mixing fluid is making mine act up slightly. Just makes an odd sound at takeoff and occasionally a small shudder between 2-3.
