Anyone know what the RPM should be at idle when warm?
Admin
Technical data for M48/00 engine (Cayenne S)
Engine design
Type
8-cylinder, four-stroke Otto engine, 90 ° V-engine
Crankcase
Horizontally divided light alloy cylinder block/crankcase without cylinder sleeves
Crankshaft
Forged steel
Crankshaft bearings
5 plain bearings, dia. 64 mm
Connecting rods
Forged and cracked, l = 155 mm
Con-rod bearings
Plain bearings, dia. 54 mm
Pistons
Light alloy casting
Piston pins
Floating
Piston rings
2 compression rings, 1 oil scraper ring
Cylinders
Aluminium/silicon running surface, mechanically exposed
Cylinder head
Two-part light alloy head, cross-flow cooling
Valve guide
Pressed in
Arrangement of valves per cylinder
2 parallel overhead intake valves
2 parallel overhead exhaust valves
Valve diameter
Intake 37.1
Exhaust 32.5
Valve lift
Intake
Exhaust
10 mm
9.85 / 8 mm
Valve control
Intake
Exhaust
Flat-base tappet
Flat-base tappet
Camshaft
Intake and exhaust camshafts driven via dual chain by the crankshaft.
Camshaft adjustment
Rotary-vane adjuster, 25° camshaft
Valve clearance
Hydraulic valve-clearance compensation
Timing at 1 mm valve lift and zero clearance, large valve lift
early/late limit
Intake opens at 19° before OT/31° after OT
Intake closes at 12° after UT/62° after UT
Exhaust opens at 22° before UT/34° before UT
Exhaust closes at 6° before OT/6° before OT
Engine
Engine type
M48/00
No. of cylinders
8
Bore
93 (3.66)
mm (in.)
Stroke
83 (3.27)
mm (in.)
Cubic capacity
4511 (275.2)
cm3 (cu. in.)
Compression ratio
11.5 : 1
Max. engine power
as per 80/1269/EEC
250 (340)
kW (HP)
Net power as per SAE J1349
340
HP
At engine speed
6000
rpm
Max. torque
as per 80/1269/EEC
420
Nm (ftlb.)
Net torque as per SAE J1349
310
ftlb.
At engine speed
2500 - 5500
rpm
Max. output per litre
55.6 (75.6)
75.6
kW/l (HP/l)
HP/l
Rpm limitation
by fuel cut-off and electronic throttle
with
manual transmission
Tiptronic transmission
6700
6500
rpm
Idle speed
580
rpm without air conditioning
(• Engine running
• Vehicle stationary
• Engine without load
• Engine temperature greater than 60 °C
• Intake air temperature greater than -10 °C)
Engine weight as per DIN 70020 A
kg
Manual transmission*
233
Automatic transmission
* including double-mass flywheel
Engine design
Type
Crankcase
Crankshaft
Forged steel
Crankshaft bearings
Connecting rods
Con-rod bearings
Pistons
Light alloy casting
Piston pins
Floating
Piston rings
Cylinders
Cylinder head
Valve guide
Pressed in
Valve diameter
Intake 37.1
Exhaust 32.5
Valve lift
Intake
Exhaust
10 mm
9.85 / 8 mm
Valve control
Intake
Exhaust
Flat-base tappet
Flat-base tappet
Camshaft
Camshaft adjustment
Valve clearance
early/late limit
Engine
Engine type
M48/00
No. of cylinders
8
Bore
93 (3.66)
mm (in.)
Stroke
83 (3.27)
mm (in.)
Cubic capacity
4511 (275.2)
cm3 (cu. in.)
Compression ratio
11.5 : 1
Max. engine power
as per 80/1269/EEC
250 (340)
kW (HP)
340
HP
At engine speed
6000
rpm
Max. torque
as per 80/1269/EEC
420
Nm (ftlb.)
310
ftlb.
At engine speed
2500 - 5500
rpm
55.6 (75.6)
75.6
kW/l (HP/l)
HP/l
Rpm limitation
with
manual transmission
6700
6500
rpm
Idle speed
580
(• Engine running
kg
233
Thank you 911SLOW. I've been driving my 993 all summer which idles at 900 rpm. When I got back into my Cayenne I was concerned at the (seemingly) low rpm of 584 rpm. I can now stop worrying.
