Front Lower Control Arm
The bushings are torn on both sides of the lower control arms. The driver side is completely torn and I can move it by hand jacked. I just picked up both control arms as I read its easier to install the whole unit vs. press out/in new bushings.
Any tricks to replacing them? What are the torque specs? Believe it or not I couldn't find this in my repair manual (anything regarding the control arm) .
I already purchased some Yuengling, Fat Tire and if that doesn't do the trick the grey goose is on stand by
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
For 1st Gen Cayenne. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Tightening torques for front axle.
Suspension subframe
Threaded connection, suspension subframe to front body, M14 x 1.5 x 150 Always replace screws and lock nuts after removal. Initial tightening 89 ftlb.
Threaded connection, suspension subframe to front body, M14 x 1.5 x 150 Always replace screws and lock nuts after removal. Final tightening 180 °
Threaded connection, suspension subframe to rear body, M14 x 1.5 x 115 Always replace screws and lock nuts after removal. Initial tightening 89 ftlb.
Threaded connection, suspension subframe to rear body, M14 x 1.5 x 115 Always replace screws and lock nuts after removal. Final tightening 180 °
Axle strut
Threaded connection, upper trailing arm to mounting saddle, M10 x 70 Always replace screws and lock nuts after removal. Initial tightening 37 ftlb.
Threaded connection, upper trailing arm to mounting saddle, M10 x 70 Always replace screws and lock nuts after removal. Final tightening 90 °
Threaded connection securing upper trailing arm to pivot bearing, M12 x 1.5 Replace screws and lock nuts after removal. Tightening torque 63 ftlb.
HBA screw connection with steel springs, M5 x 10 Tightening torque 3.5 ftlb.
Level regulator screw connection with air springs, M5 x 10 Tightening torque 3.5 ftlb.
Threaded connection securing lower trailing arm to suspension subframe, M14 x 1.5 x 105 Replace screws and lock nuts after removal. Tightening torque 133 ftlb.
Threaded connection securing lower trailing arm to pivot bearing, M14 x 1.5 Replace screws and lock nuts after removal. Tightening torque 78 ftlb.
Steering gear
Threaded connection, steering gear to suspension subframe, M12 x 1.5 Always replace screws and lock nuts after removal. Initial tightening 67 ftlb.
Threaded connection, steering gear to suspension subframe, M12 x 1.5 Always replace screws and lock nuts after removal. Final tightening 90 °
Threaded connection securing tie rod to pivot bearing, M14 x 1.5 Replace screws and lock nuts after removal. Tightening torque 67 ftlb.
Tie rod to tie rod end screw connection, M14 x 1.5 Lock nut Tightening torque 52 ftlb.
Heat shield screw connection, M6 x 16 Tightening torque 7.5 ftlb.
Tie rod to steering rack screw connection, M18 x 1.5 Axial joint Initial tightening 74 ftlb.
Tie rod to steering rack screw connection, M18 x 1.5 Axial joint Final tightening 10 °
Pressure line to steering gear screw connection a/f 17 a/f - wrench size Tightening torque 22 ftlb. ±2 ftlb.
Return line to steering gear screw connection a/f 17 a/f - wrench size Tightening torque 22 ftlb. ±2 ftlb.
Steering column to mounting bracket screw connection, M8 x 28 Tightening torque 17 ftlb.
Steering column to mounting bracket screw connection, M8 x 10 x 45 Tightening torque 17 ftlb.
Expansion/return line screw connection, M6 x 12 Tightening torque 7.5 ftlb.
Wheel carrier (pivot bearing)
Speed sensor to wheel carrier screw connection, M6 x 16 Tightening torque 6 ftlb.
Brake cover plate to wheel carrier screw connection, M8 x 12 Tightening torque 15 ftlb.
Threaded connection securing brake calliper to wheel carrier, M16 x 1.5 x 48 Replace screws and fastening nuts after removal. Tightening torque 200 ftlb.
Brake hose holder to wheel carrier screw connection, M6 x 12 Tightening torque 6.5 ftlb.
Cable retainer to wheel carrier screw connection, M8 x 14 Tightening torque 22 ftlb.
Brake disc to wheel hub screw connection, M12 x 1.5 x 16 Tightening torque 10.5 ftlb.
1) Replace screws and fastening nuts whenever removed.
Spring strut
Spring strut to trailing arm screw connection M14 x 1.5 x 102 Initial tightening 111 ftlb.
Spring strut to trailing arm screw connection M14 x 1.5 x 102 Final tightening 90 °
Spring strut bracket to piston rod screw connection, M12 x 1.5 Tightening torque 44 ftlb.
Mounting saddle screw connection M8 Tightening torque 22 ftlb.
Mounting saddle to body screw connection, M10 x 37 Initial tightening 37 ftlb.
Mounting saddle to body screw connection, M10 x 37 Final tightening 90 °
Residual pressure restraint valve screw connection Tightening torque 2 ftlb.
Suspension subframe
Axle strut
Steering gear
Spring strut
You didn't mention what year or model you have but at least for the V8 versions you can use the heavier duty versions from the Turbo S. They have thicker rubber bushings which have shown to hold up much better than the regular ones. Not sure if they fit the V6 versions but probably do.
