23mm Spacers Front and Rear....
Hey Guys/Gals,
We wanted to test a theory: wheel spacers would give the appearance of being lowered, so we fitted a 2008 Cayenne Turbo with some 23mm front and rear spacers.
Without Spacers:
![](http://www.gmpperformance.com/CFJFiles/GMP/21747.jpg)
With Spacers: (The rear air suspension was set high)
![](http://www.gmpperformance.com/CFJFiles/GMP/21750.jpg)
MORE PICS:
When adding wheel spacers to your Porsche Cayenne, Audi Q7, and VW Touareg , it is very important to use the correct length bolts. GMP sells the spacer kit with the correct bolts to make it convenient and easy for our customers.
We have these kits in 15mm, 18mm, and 23mm HERE:
Without Spacers:
MORE PICS:
Looks good to me! The rears seem a little bit too out for my taste. Are there smaller spacers ?
I have been thinking on doing that to my CTT. I have currently 21 wheels as well
It would have been better if you took the picture of before & after from the same angle. Can't really tell the difference to tell you the truth.
How? set your camera on tri-pod and take the picture before & after, pretty simple.
