Is this a good deal for 08 CS CPO
Hello everyone,
this will be my first porsche below you will find the order list , it has about 45 k.ml. at $ 39K , including the rear seats DVD is it a good dealÉ
In service date Dec.10.2007.
Also checked the PIWIS info sys. print out it looks like only one issue it has `replaced broken stopper In Cam`
WA292 fuel pump, WA06 air bag and coolant y pipeépump were done does the later means the issue with the coolant pipe is resolved. i could not attach the file as it is 1.5 MB.
on another note i would like to install the XM radio and bluetooth does $2000 installed and tax in sounds fair for these items.É since it is under CPO warranty i did not like to have an after market solution that would affect the 2.1 PCM warranty. however if there will be no issue with the warranty then will go for it and might as well add the rear view cam..any thoughts on this
Thank you all for the kind help,
BASE S 57,900.00
D4 Green Olive Metallic 690.00
D4 Green Olive Metallic 0.00
VU Havanna/Sand Beige Leather Int 0.00
PE1 Comfort Seats w/ Memory 930.00
PO4 Light Comfort Package/Memory 610.00
0TD Front & Rear Flr Mats Int Clr 140.00
3S1 Roof Rails in Aluminum Look wi 1,190.00
3X1 Ski Bag 0.00
3Y4 Roll up Sunscreen-1/4 Windows 190.00
PPB Preferred Package Plus 8,490.00
3FE Moonroof 0.00
1D6 Trailer Hitch w/o Hitch Ball 0.00
1NP Wheel Hub Covers Colored Crest 0.00
7A2 6 Disc CD Changer 0.00
PF1 PCM 2.1 0.00
PC3 Bi-Xenon Headlights w/ Washers 0.00
PK1 Front Seat Heater inc Str Whl 0.00
9VL Bose Surround Sound System 0.00
Total with Options %msg%nbsp; 70,140.00
DSTCHG Destination Charge 975.00
Total Charges %msg%nbsp; 975.00
Total Order %msg%nbsp; 71,115.00
BASE S 57,900.00
3X1 Ski Bag 0.00
3FE Moonroof 0.00
PF1 PCM 2.1 0.00
