GTS Parts Question
GTS Parts Question
I'm editing my post. I took a good look last week and saw some parts that I want to put on the front of my 06 S Titanium Edition.
Up front there are two small spoiler/wing lips under the fog lights. By the looks of it they would be an easy install on my 06. I'm not crazy about some of the body kits out there, so for me this is just sporty enough. I was planning to order the parts from Suncoast and then have them painted and installed by a body shop here. Question 1)
Does anyone no the Porsche Part numbers for the lip wings and mounting hardware?
Second question was already answered about the rear double wing, but I found an OEM online for $900 that is a supposed to be a direct replacement for 03 to 06 cayenne's so I'll probably end up getting that.
The last question is about GTS rims. Does anyone know the part number for the 20" (I believe they are 20's) 5 star, 10 spoke, GTS rim. It's similar to the one in this ebay auction, I want original Porsche...
http://cgi.ebay.com/ebaymotors/Porsc...mZ150588693909
Any help would be greatly appreciated. Thanks
The V8 Porschephile
The bi-plane wing on the GTS will fit pre-'08 models provided you replace the lower base at the same time. Only then will it fit your '06. The mounting lugs are similar and the 3rd brake light can be swapped from one wing base to another. It's not a bolt-in fit but it can be done with a little brain work.
The V8 Porschephile
Mac, please tell me that you're not going with this roof spoiler.
This is NOT a German tuner spoiler but simply a generic Asian-made fiberglass replica of a Toyota Corolla SE trunk spoiler that gets screwed into the factory unit.
http://www.porschewheel.com/porsche-...-spoiler-p-534
It appears to be a good OEM of the GTS that requires little modification to mount.
Still looking for the part numbers for the front lip spoilers and GTS rims if anyone has them.
The V8 Porschephile
It's seems a tad expensive since the dealer charges less than $600 for this same part. Have you checked with your dealer's parts dep't yet?
The V8 Porschephile
Yes. The bi-plane spoiler consists of an upper half spoiler shell as well as a smaller wing that attaches to the spoiler. They come in a primered form and require painting. They cost just under $600.
The lower half of the spoiler which houses the XM antenna, 3rd brake light and other electrical goodies already resides on the '08+ Cayennes. Installation is as simple as removing the existing upper half and replacing it with the newer bi-plane unit.
On older pre '08 models, the lower half spoiler shell must also be purchased so as to install the new bi-plane spoiler. The two combined cost well over $900 however, the 3rd brake light from the older unit can be saved and re-used on the newer unit.
I've got a set of 21in factory OEM GTS wheels, with tires and sensors in porsche totes sitting in my garage that I've been considering selling. Tires have about 90% tread life left.
I have aftermarket wheels on my GTS so don't really need these. Make me an offer and I might be up for passing them on. Rims are in perfect condition.
I picked up this GTS wing on eBay, of course it arrived broken in one corner, not sure of quality as had it shipped to my body shop an hour away. He also sells a carbon fiber one, might be stronger for the shipment over from China.
http://www.ebay.com/itm/171082089320
