Water Leak! pls help
4th Gear
2006 CS, 46000miles. I accidentally pulled out in front of someone so i floored the Porsche and it started pouring water. Not sure if gettin on it hard had anything to do it with, but just making sure. Anyway, I crawled underneath and I swear it looks like it is spewing out of the block/engine housing. There are a few holes in the aluminum housing/block right in front of the oil pan. It really looks like it is spraying out of those holes. I topped it off and parked it right away. It never got over-hot and ran/drove fine, except for steam pouring out of it... Please advise!
4th Gear
Ok, i did look at that post first and was not sure, BUT i have since read through all 14 pages and yes that is probably the same problem i have. Thanks.
