2008 Porsche Cayenne Interior trunk button not working??
Take the switch out, and connect the TRUNK pins on the small wire harness, you need to make sure that you shorting the correct pins, as there are 4 - There are 2 for the LED, the other two are for the actual switch contacts for the trunk- complete the circuit across the two pins for the gate & if the gate closes, then you know that you have a switch problem- if this is the case, you can pry the tabs on the switch, and open it up and see what's going on with the contacts inside-
I have the same issue. Did you resolve it? The button on the hatch/trunk does not work always.
Thanks. I will try. Also read that low battery voltage could give intermittent problems with the hatch button, i'll try to charge up the battery as well.
