Cayenne issues w/codes
Old Oct 23, 2010 | 06:06 PM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
Default Cayenne issues w/codes
My 04 Cayenne S is throwing 2 codes, no CEL.
DME:
907
Load management operat. on vehicle
electrical sys./DME control module
Present
No other codes or engine miss, slight tick from engine??
Coils?
Other one is the Air suspension, I get the "Faulty message" on startup now and than. Code is:
1772
Signal lead for pressure sensor
Pretty sure I can solve this with the VW Compressor rebuild kit.
Old Oct 27, 2010 | 12:51 AM
CDH-CTT's Avatar
CDH-CTT
Do you still have a FACTORY Porsche battery still??
P!gs hate low batteries.....
Carl
Old Oct 27, 2010 | 07:10 AM
mudman2's Avatar
mudman2
Moderator !x4
I do not see a DME 907 error listed, but it sure sounds like the battery is toast
0907 Load management operation on vehicle electrical
system/DME control module
♦ Limited load functions
♦ Idle speed increase
43-1772 Fault code 1772
Pressure sensor signal lead
Diagnostic conditions
• Ignition on
• Internal function test on level adjustment control unit
Possible cause of fault
♦ Short circuit to B+ in the wiring of pin 84 of the level adjustment
control unit
♦ Short circuit to ground in the wiring of pin 84 of the level adjustment
control unit
♦ Open circuit in the wiring of pin 84 of the level adjustment control
unit
♦ Level adjustment control unit receives implausible signal from
pressure sensor
♦ Pressure sensor faulty
♦ Level adjustment control unit faulty
Affected pins
Level adjustment control unit, connector A:
♦ Pin 34
Level adjustment control unit, connector B:
♦ Pin 84 'P signal'
Solenoid block, connector A:
♦ Pin 8
♦ Pin 9 'P signal
Could be a strut sensor, PIWIS will identify
Old Oct 27, 2010 | 11:38 AM
Marc Gelefsky
Super Moderator
Off to a shop with a PIWIS I go!
Old Nov 24, 2012 | 12:52 PM
hahnmgh63's Avatar
hahnmgh63
To resurect this thread. I had the occaisonal Workshop fault with code 1772 and did the complete compressor rebuild (the rubber compressor piston ring was definitely hardened) but it didn't solve my problem so I'm going through the troubleshooting phase starting today. The suspension seems to work normally other than the fault. I did find this Touraeg TSB which may help some as the parts seem to be all the same. Comes on every time about 1 minute after startup.
