advice on loss of performance on 4.8 turbo
seems to lose boost at the top end, after 5000rpm ot goes down to .4 bar still seems as quick to 100mph but after that seems to struggle,,
where it used to pull 160 easy seems to struggle to get over 140?
anyone got any ideas?
i'm sure if i took it to porsche they would say its fine as they couldn't perform such test!
thanks andrew
thanks andrew
not notice longer cranking but will look for that now, also when you cruise around 60 mph it gives a wee missfire now and then, i put that down to plugs as its done about 43k miles on the original set
its out of warranty but i'm going to take it to porsche for service and get extended warranty and hope the coils etc pass inspection then put it back in and see if they will fix the issues?
coils my not be coverd thou?
are they unique to porsche or can be sourced throu vag groupa or that?
i have a shop so tools are no problem.
http://www.moorfieldmotorservices.co.uk/
