I thought about typing sedan instead of car myself. But having owned a couple of highly modified Audi "Sports Sedans" I actually think the CTT handles better.
As strange as it may seem some seemingly minor elements make this thing handle more sports car than sedan when pushed hard.
....and just for the fun of it. This one was hanging just fine in the corners and overpowering on the straights. (with snow tires) Obviously there may be some driver differneces, but it is still pretty track capable.
Super Moderator Needs More Cowbell Lifetime Rennlist Member
A V8 Turbo overpowering a 964 on the straights ... yawn.
This is usually followed by the V8 Turbo holding everyone up in the turns and the cycle repeats endlessly.
Your posts and repeated bashing of a car you don't own. YAWN! ...
Yes, it's nice to be able to say that ... at least until one side or the other lifts the restraining order
However, it nice to see the Cayenne has a growing fan base.
.....and the engine size and induction should not matter. Its all power to weight.
Power to weight...in a turn....care to think about that for a moment?
A large, high center of gravity vehicle is more likely than not going to hold up a smaller lighter lower CG vehicle in the same turn.
Don't make me dig up Sir Isaac Newton ... he was resting after a long late night game of poker with Albert Einstein and Larry.
Y
See, there you go with you inability to actually read and follow a conversation. Inserting what you want and twisting it to serve your Cayenne hating agenda.
YOU were talking about a V8 Turbo's power in A STRAIGHT LINE. I was replying to your comment about the ability of one car to overtake the other IN A STRAIGHT LINE.
...and FWIW a high roof line is only one variable. Suspension design and the actual location of the weight has a lot to do with it. The Cayennes weight is not on the top.
We get it already!!! You are one of those old school purists that can't stand the idea that Porsche ever made a SUV. So you somehow think that if you can convince every person in the world they are bad Porsche will somehow go back in time and only make poor handling underpowered air/oil cooled cars.
If they did not make the Cayenne Porsche would be only a memory at this point.
Don't get carried away with yourself. I wouldn't call the 964 a poor handling or under powered car. Let's see, your CTT is what 10 years newer, it has more technical innovations behind it (suspension, brakes, etc). Let's see, your CTT has what, 100hp more power plus it's a turbo, must I go on.
How did the CTT handle the yellow vette in the pic?
You may have beat the "old" 964 but you have alot of advantages over it, post pics when you have a 997 out there with ya
The Vette was always behind the CTT for as long as I was watching. (a few laps, but I don't know anything about any of the drivers or the car set ups either)
I consider the 964 poor handling and under powered compared to my older better balanced and more powerful 951
YOU were talking about a V8 Turbo's power in A STRAIGHT LINE. I was replying to your comment about the ability of one car to overtake the other IN A STRAIGHT LINE..
Sorry, I thought I saw some not straight sections of track in those pictures, sort of a poorly laid out 1/4 mile drag strip ... my apologies, I thought they looked a lot like what I would have called 'turns'.
...and FWIW a high roof line is only one variable. Suspension design and the actual location of the weight has a lot to do with it. The Cayennes weight is not on the top. .
Where is the engine CG relative to the vehicle CG?
Is the V8 as optimal as a flat 6 for CG?
The weight is certainly a lot closer to the top. There comes a point where suspension travel runs out and the Titanic lists to starboard and sinks...although usually the tires give up before that.
BTW, folks will go to extreme lengths to remove a sunroof to help with CG and handling....folks being Carrera folks.
Porsche is only a memory at this point. No longer an independent company, now just a badge under the VW umbrella.
Did you not get the memo?
I heard it too many times from Dr. W.; how exactly did that story end?
Dunno about that, the 964 as far as a straight line is pretty much on line with the 944t. cant say its better balanced than a 944t since i have never driven one but the 964 was definately not a poor handling or underpowered Porsche
I heard it too many times from Dr. W.; how exactly did that story end?[/QUOTE]
More of the old school attitude.
I would agree with you if it were any other company. Porsche and VW were wtarted from the same family tree and have shared bits and pieces since day one. If Porsche has any chance its with VW.
