Could high altitude cause air suspension warnings...
Old 06-06-2010 | 09:25 PM
Cole's Avatar
Cole
Originally Posted by prsdoc
If it becomes a recurrent problem, consider trying this solution:
http://www.renntech.org/forums/index...004-cayenne-s/
Any idea where to get this kit? I can't find anything with that part number.
Would like to avoid going to the VW dealer if I can.
Old 06-07-2010 | 01:40 AM
prsdoc's Avatar
prsdoc
I think you may need to head over to the VW dealer for the Piston Ring Repair Kit:
http://www.clubtouareg.com/forums/f6...t-12583-2.html
It may also be part 7L0 (zero instead of "O"?) 698 030.
Old 08-16-2012 | 11:00 AM
ssharp225's Avatar
ssharp225
Thank you for the rebuild link! Was concerned this would not be a DIY.
Old 08-16-2012 | 11:32 AM
Cole's Avatar
Cole
FWIW it only took me about 20 minutes to do the entire job. Most of that was screwing around.
Old 08-16-2012 | 11:50 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Mine was rebuilt after I orginally started this thread. It's working well now.
Old 08-16-2012 | 03:11 PM
rbaron's Avatar
rbaron
I see this thread has re-started. See my post (#8, above) and here is the update: I still get the warning very intermittently. I am almost afraid to mention it because it has probably been a couple of months since I have seen it. On 12-21-10 the tech was able to finally get a fault code and here is his note: "C/S Air Suspension Warning Light is On. Level Fault #1772 Pressure Sensor Signal. Estimate: $1107.31."
In his words it is the sensor that has gone bad, not the pump, but it is a major deal to get to the sensor to replace it. Needless to say, I have not had it replaced.
This will raise an issue when I sell or trade the car in a year or two but I'll deal with it then.
--Bob
Old 08-16-2012 | 04:35 PM
ArneeA's Avatar
ArneeA
Pressure sensor should be located at or close to the reservoir tank. It's a common issue on some makes, but I don't see why it would be a big deal replacing it. It's simply a sensor on a tank.
Old 08-20-2012 | 12:40 PM
Mar-One's Avatar
Mar-One
3rd Gear
Hi,
I have problem with my front right airsuspension (Cayenne 2003). When I turn of the car the front right side of the car go's to a lower level then the other tires. Once I start the car, the front right side of the airsuspension go's again up and is on the same height us the other tires. I get also from time to time the notification of airsuspension on the board computer.
Does anyone know what the cause could be of this failure?
Edit
Report
Old 08-20-2012 | 02:54 PM
jerry joseph's Avatar
jerry joseph
Originally Posted by cordsig79
I have a license plate cover that says "This boat runs on GAS, Not Friendship".......
Now I did sell my boat but the license plate does still seem fitting .
Quick Reply: Could high altitude cause air suspension warnings...
