Fuel Filter? is it a DIY project?
#31
Team Owner
These are great instructions. I'm unclear why the tank needs to be drained. It looks to me as if the filter is on top so no fuel would leak out while R&R'ing the filter assembly. What have I missed?
#32
Here is also one of those savings if you order by the VW part # stamped on top of the filter (VDO manufactured). 7L0919679 You can pay three times as much by buying the Porsche part but it is still going to be the VDO manufactured part with the VW part # stamped on it like the one in the picture on page two.
#33
#34
It's amazing how often this happens. I replaced a section of the exhaust in my V6 with the VW part for the Tuareg. The only difference - other than it being several hundreds of $$$ cheaper - was the VW part had a support brace that had to be cut away; the Porsche version is two individual pipes. Other than that: identical, right down to the location of the oxygen sensors. I'm sure they come off the same line, and someone spot welds the brace on the VW part before boxing them.
#35
Easy DIY...
In less than 30 minutes.... you can do this without ever going into the other side of the tank and cut carpet(2004-2006). Just make sure the fuel level is exactly at 1/4 tank, and you replace ONLY with OEM VDO flange:
#37
https://www.youtube.com/watch?v=lCLMTul1KUk&t=337s
#38
I tackled the Fuel filter replacement this morning. The fumes not so bad, but I did wear a paper mask. Pretty straight forward following the "iFixIt" DIY.
I recommend to have your fuel filter serviced (Porsche recommend every 36K miles.) When I unplugged the fuel lines, the fuel coming from the filter unit was filthy, pretty much black.
FEW POINTERS:
The top electric connector on the "Driver" side is just stupid PITA to remove. There is just no space to push it out to unlock, awful (passenger side comes right off).
I do suggest to buy the VW tool to remove the rings ($39 on EBay), as on the "Passenger side", you will get some fuel spills removing the upper fuel hose and I would not recommend hammer and screwdriver, It takes one spark .....
Now, one more thing to mention, there are two electric connectors on the bottom of the fuel filter (yellow and green) When assembling everything back, I could not find the green one to plug it back in for quite some time, it was hiding under the fuel pump on the bottom of the tank. You will have to fish it out, reaching to the bottom of the tank. It is not deep, but you don't want to have too much fuel in the tank to be able to see it or needing longer gloves. (made me worried at first, I thought it broke of or something). Now you know where to look. The car started right away after the install, no issue there.
With the seats removal, this will easily take you couple hours, My indy would have charge me at least $250 for labor. SUCCESS :-)))
FEW POINTERS:
#39
FEW POINTERS:
FEW POINTERS:
#40
957 GTS fuel filter is a sealed unit, you cannot unscrew it and replace the internals. I would just order from any reputable source the model specific unit, last thing you want to have any fuel delivery issues.
Fuel filter: 95562042100
Sealing ring: 95520113301
#41
#42
