Washer Fluid leak
Washer Fluid leak
Did a quick search and found some mention of headlight washers leaking. I don't see a leak, do they actually leak or does a torrent of water come out so if I wash my windshield at night while at speed, four tugs dumps out 2 gallons of fluid at the front?
Why not just do a test in your driveway? Have someone operate the washer while you watch. It may be difficult to tell exactly how much it leaks because if it is a small one at the fitting it may take a while to drip down and in the meantime the fluid you sprayed on the headlight will also drip down. But at least you'll know if it is worth worrying about.
Basically querying the group knowledge base here instead of dissembling the whole system looking for leaks, I would rather start with known common issues if any. I fill the tank up with two large bottles, and don't recall using the washer fluid but in 3 weeks a light comes on. In my touareg I usually go between 5000 mile oil changes and fill it then with no light lit up. I figure it is the same size tank. I have not seen any obvious peeing on the driveway.
Well I found something, not worth posting pics. The long white filler tube looked good, but I pushed it in near the tank (behind the right hand light) and it went in about 2 inches and I think clicked.
Let's see if that makes a difference!
Put it all back together and it is not leaking for now, I am sure it will in a few days again.
No if i can just find out how the water is getting in the back hatch....
So it has been nearly a month now and no leak, I am assuming the O ring on the C clip had dried out and leaked a that joint. Seems to be good for now...
Well I still had a leak, pulled the bumper off and found it was leaking at either the joint where the hose connects or the rotating connection on the washer jet itself. I pulled the plastic C clip on the US passenger side jet and drained the tank, cleaned it out, rotated the connection to loosen up the joint and let it sit in the sun for a while, while I replaced a headlight mount/tray (another story)
Not a problem, still doesn't leak, but I suspect I am on borrowed time, once the winter comes, i am sure it may leak again.
