KESSY problem
5th Gear
Almost Same problem for me, 2004 4.5S, when i remove key from ignition i hear a click, when i close door and tip on door handle everything is fine.
When i remove key sometimes i donot get a click , closing with tip does not work then.
With remote i cannot close door and put it on alarm(i have replaced battery). I also remover kessy unit and checked connections, everything looks Oké but problem is still there. Where can it find rear control unit?
5th Gear
Hi,
I checked all antenna and kessy module, removed all connections and have put them back, problem still the same.... But I also on the web a link to the ignition switch, I remoeved panel etc and switch, the connector to the swicth was not connected very well and the housing of the switch was a little bit lose, I openend iet cleaned it and put everyting back and my kessy problem has been solved it works fine!!
what is noticed when I removed the key( i donot use dummy key because it fails to work) sometimes i did not hear the final click , position of key on ,ost left position, and car was not locked and when i put key back car refused to start. The moving key several times from right to left the car started without any problems.
Now is comes, I parked my car and get the steering faulty error,
Now my car is at a porsche specialist for 2 weeks and this is what they did so far: put new igintion switch in car, still steering faulty problem, now the jhave put a brand new steering colum in th car, erro is gone but car refused to strat immobiliser error. My specialist has no piwi tester so car was send to official porsche delear and the cannot solve issue even with piwi tester!!
Now the advise to replace all comminication boxes between steering column and iginition unit..................PLSE HELP ME! I'm spending a fortune!
So...I just read Porsche 52's responses (which were really helpful) and I think I can now ask more intelligent question. I discovered that the vehicle will start with the dummy key in the admission and the key fob close by (but not 30 feet away). I can also open the rear hatch with key fob in my pocket.I cannot on lock or lock the vehicle doors with anything other than the remote buttons themselves. Does this help localize the problem?
2008, Cayenne turbo
2008, Cayenne turbo
Porsche 52 thanks for great and useful info!
I have a question for you. Do you think the Porsche entry and drive system could be added to a 06 CTTS that didn't originally have it? On the build sheets it's only a $950 option. I know when you piece meal it gets a little more but I was thinking could I just change the ignition switch, add the Kessy unit, change the door handles and add the antennas. Would you happen to know if the wiring is already there?
Any thoughts?
Any thoughts?
Excellent detailed post P52.
I also found a similar Kessy description previously but it was applicable to a Bentley, not Cayenne specific.
I am happy with the internal antennas as the car starts with the dummy key as you have stated.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
As mentioned earlier I cannot lock or unlock from any door handle.
I should mention that I also don't have any unlock action from the rear tailgate open switch or the tailgate glass open switch when the vehicle is locked. Are these tailgate open switches hardwired, discrete inputs into the Rear control module?
If so this leads me into thinking that it could be the Rear control module at fault.
The dealership that is looking into this fault has ordered all the external antennas to be replaced as they had diagnostic faults of all the external antennas being shorted to ground.
I find it hard to believe that all my external antennas have all gone faulty at the same time.
Could it be a case of one faulty external antenna is dragging down the rest of the system?
Anyways, it's times like these I am happy that I have the CPO warranty.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Only hitch is that the antennas are not in stock here and have been ordered from Germany. (2-3 weeks delay)![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Hope they fix the problem.![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Hi I can't unlock or lock the floor from the Handel but I can do it from the remote .
when I scanned the with OBD I got that the luggage compartment antenna has shortshort-time B+
I opened all the covers in the luggage compartment but couldn't find the antenna dose any one know where to find it ?
plzzzz help
plzzzz help
Received 1,149 Likes
plzzzz help
plzzzz help
The luggage compartment antenna is located in the spare tire well somewhere.. if you've experienced flooding in the spare tire well, chances are it drown.
BTW- I deleted the duplicate post you made in a new thread. Let's try to keep all the KESSY problems in one thread.
plzzzz help
plzzzz help
My KESSY decided to stop working today ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I can start the car with the plastic control unit but cannot unlock or lock the car via any door handle/button.
Does anyone know how to get access to the KESSY control unit as I want to check out the connectors ?
Also the antenna locations for the KESSY would be appreciated.
Thanks.
Thanks.
https://rennlist.com/forums/porsche-...l#post14872295
Hi all have a similar issue key clicks door open and lock key in ignition no start.... (04ctt) Pulling errors I get gateway and Kessy.
can anyone tell me where the Kessy is cannot find it and want to send that away to be reprogrammed with the key and steering lock control unit to speedometer unless any other suggestions can a Porsche pwis fix this ? Help my car has been laid up for 6 mths.
They replaced the interior and rear bumber antennas along with the Kessy control unit, only to have the control unit "blow up" after 5 minutes.
Next they fitted a new "alarm control unit"
and another Kessy control unit.
End result is that my keyless entry is working better than ever. Very crisp and sharp response as soon as you touch the door handle.
What do you think P52 ?
Fault code 1330 relates to the Rear convenience system control unit.
The fact that you have all the other codes which relate to the Kessy antennas all appearing could be a result of a malfunction of the rear convenience system control unit circuit or the Kessy module / circuit.
It is unlikely that all those antennas have simultaneously failed.
I would be first checking the rear convenience unit circuit and reseating it’s electrical connector for starters.
If ok then you may have a faulty Kessy module / circuit.
