Rear Liftgate
Rear Liftgate
So about 50% of the time when the truck is unlocked the rear gate and hatch will not function. I can pop the glass with the remote and if I use the inside switch for the gate it will open, otherwise i need to pop the plastic cap off the inside and do it manually. It's an '05 CS. Anybody ever have this issue or know of a solution.
Thanks in advance
Andy
Thanks in advance
Andy
Just a quick update with some additional info. The doors and alarm are now arming themselves. I had the hood open today and I had to repeatedly hit the unlock button on the remote because the doors kept locking and alarm setting. Another thing that has started happening is that I never used to be able to lock the doors with the fob when the drivers door was open, now it will lock the doors and the alarm will start to go off.
Whenever you unlock the car with the fob and you dont touch a door, hood, etc, it arms itself again. Since you dont open the hood that often, I wouldnt be suprised if the switch is stuck down.
If you leave the drivers door open, after you pop the hood, I bet the alarm wont arm.
