Wheel Bearings going bad??
Old 10-22-2009 | 02:10 PM
Stone43's Avatar
Stone43
Default Wheel Bearings going bad??
Yes, I did a search. Found nothing.
I am getting a strange noise coming from the front of my car at different speeds. At first I thought it may just be the tires but the noise is getting worse and I suspect that my drivers side wheel bearing may be going bad.
04, Cayenne S, 83K on the clock. No mo warranty.
What are the symptoms of a bad bearing? Has anyone had the repair done and if so how much (see above, no mo warranty)?
Old 10-22-2009 | 02:33 PM
Adam Conrad's Avatar
Adam Conrad
I had bearings go out on my 964 and it feels real bad - especially when I was on Watkins Glen at speed! Jack up the truck and see if there is play by pushing on the wheel from top and bottom. If it is real bad, it will move considerably.
Old 10-22-2009 | 04:31 PM
Stone43's Avatar
Stone43
I don't really "feel" much, it is mostly a noise. No major vibrations either.
Old 10-23-2009 | 05:55 AM
Edmac's Avatar
Edmac
Default Same problem
I have exactly the same problem, 78K miles and very noisy at the front end. My control arm bushes are worn but not sure if that's causing the noise.
Any ideas?
Old 10-23-2009 | 07:50 AM
mudman2's Avatar
mudman2
Moderator !x4
sure its not the front diff ?, they get noisy
Old 10-23-2009 | 11:16 AM
T2's Avatar
T2
Stone43,
My experience with wheel bearings going bad is if your take a turn (say in an exit ramp) you will hear a thud, thud sound if the bearing is shot. Basically a lateral load on the wheel while moving will indicate it best - again my experience.
Hope that helps.
T2
Old 10-23-2009 | 12:51 PM
User 4221's Avatar
User 4221
+1 on T2. Lateral loading will make them louder.
If it is constant, then it may be the diff or CV joint.
