engine problem
Need advice.
I recently had my 04 turbo in the shop for a check up due to it running like *** . they concluded that the truck needed a new turbo and the timing chain needed to be replaced. They also told me that it had 1,3,7, cylinders out due to the c coil packs not firing. The truck only has 50,000 miles on it. I had all the coil packs and all the plugs replaced the other day and all was fine till today when the engine light came on.
Maybe I’m on the wrong track but I was thinking the timing chain code came up due to the 3 dead hole. The truck runs like a champ now but as I said the check engine light came on again. If it was the timing chain wouldn’t it run like a$$? Could it be something different? Anyone else have this problem?
How is it idling? With a timing chain problem (stretch) the passenger side bank's timing becomes out and your idle is rough. Soon as you're on boost/higher rpm things smooth out. Didn't think they needed to replace the chain and could adjust it?
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
This is a no brainer, replace all coils with the most up to date coil packs. They all crack, very well documented failure.
Bank 1 (and bank 2)– Signal Implausible. I would seek a second opinion from another indy or good dealer. I have talked to heard of other techs/shops replacing solenoids all day long and fixing cars. Some cases require the vane adjuster on the camshaft to be replaced too. It is very strange though, we see a ton of Cayenns here in CO, and at our shop we have done very very little vario cam solenoid/vane adjuster repairs. I have seen the faults from time to time, but no present, re-occuring faults. ??? I have been told that the intake camshafts are slow to retard timing when coming down to idle, this causes a lopy, rough idle. Lack of oil changes has been a culprit too.
I would seek a second opinion before I pulled the trigger. Just my .02 cents!
So I am wondering if I need engine mounts, to clean the throttle body or if something else's at play that is making my idle rough. Can oxygen sensors be a culprit? I have about 128k miles on the car and the emissions equipment is original... I believe.
TIA
A long time ago you posted a message above about a Cayenne having problems. I have a 2008 Cayenne GTS. I have a rough idle with faults all on bank 1 and cyl 3 misfiring only at idle. As soon as I apply and throttle engine smoothes and no misfire. Full top end power. I have been replacing parts for several months and not fixed.
Can you better explain why a stretched chain could only affect bank 1? Also, how do you check the chain without disassembly?
I appreciate your time in helping me with this. If you don't mind reading my recent fully detailed postings it would truly be appreciated. At the moment I am at a loss as to what to do.
If you search "2008 Cayenne GTS MIND BOGGLING ENGINE LIGHT ... BEGGING FOR HELP" in the title bar you can find my posts.
Thanks for your help.
