Frog sound behind dash
I have a sound, that sounds like a frog or cricket somewhere behind the dash / radio / Climate control.
Ignition must be on, but not necessarily running. Turned off climate control too see if it was a fan noise, no change. Its not repetitive, very random sequence of sounds.
Any ideas?
Any ideas?
Rocky Mountain High
Fan blower motor would be my guess. The bearing is wearing out. I haven't changed mine, but I understand that it is a relatively simple and inexpensive DIY project.
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
Rocky Mountain High
We need a few sound clips here to compare the frog noise to the chirping noise. I hear an occasional high-pitched "groan" from behind the dash, which I thought was the servo motors...
Super Moderator
Needs More Cowbell
Needs More Cowbell
Another possibility is Larry reaching out from beyond the grave and using the center dash speaker to generate these sounds.....just saying.
