Options and Reliability
I am starting the serious search for a Cayenne. I know that this may not be the smartest choice (an X5 would probably be more reliable) but for some reason I like the Cayenne. It may have something to due with that strange, modified flag from Stuttgart. It may be just how nice a Cayenne drives at high speeds.
Anyways, I have been looking at ’05 or ’06 CS. I have learned from this forum that buying an alpha or beta model is taking one’s life into their own hands as all of them will experience spontaneous combustion.
There is one option I MUST have. Litronic lights.
Now there are a few options that I have questions about. The Bose sound system. Other Porsches have had issues with the Bose system and the Bose systems can have issues. Are the Bose sound systems problematic in the Cayenne?
Air suspension. It seems pretty cool. But really, I only see mild rock crawling in store for the Cayenne so would I really use the adjustable ride height? It seems like extra weight and complexity. Does this option make replacement shocks more expensive? Is the air suspension problematic?
Turbo. Really, for not a whole lot more money I could buy a Turbo. I have driven a Turbo in Europe and loved the power. With other Porsches, the turbos tend to be more expensive to fix, more prone to breakdown, and in general 50% more expensive to own than a non-turbo of the same model. And the problem with turbo cars is that boost can be adjusted. So, is the CTT much more problem prone and generally 50% more expensive to own?
Would a “standard” Cayenne S with regular springs and sound system be about the most reliable of the bunch?
-Dana
-Dana
I have an '06 with regular springs and Bose. The car is reliable except for one issue with the ignition coils, which got replaced under warranty. The cost of owning the car is primarily from replacing tires (about every 18K miles) and brakes (about every 30K miles).
When I bought the car, I planned to keep it for long term. Thus, I believe in keeping things simple -- no air suspension; no navigation, no Turbo (or Turbo-charged insurance premium). From what I've read, these options aren't particularly trouble-prone from '05 onwards ('06 is best). However, there's no telling what would happen when the cars get older. One thing is for certain, if you need to repair anything outside of warranty, it will cost you an arm and a leg.
Rocky Mountain High
I would buy an extended warranty or buy a CPO car with a Porsche warranty if possible. As for your thoughts on reliability, you might not do much better with an X5. They have a host of problems too.
I think the Cayenne S is a good option, especially a 2006 or later. That being said, my 2004 has been essentially trouble free, with only a few minor issues so far. I've never replaced the coils, I've never had any problems with PASM, I've never replaced my cardan shaft. They aren't all bad...
As for options, I agree that Litronic headlights are nice. I would get those. I also really like the look of larger wheels on the Cayenne. I recommend 20s. If you have PASM, you can drive the car in the "low" setting to make the appearance more aggressive. You can also set the suspension on sport, normal or comfort, depending on how you want it to ride. I think it is a really nice option. Others you might consider are comfort seats and parking sensors. They make it much easier to park a large vehicle. I also have the nav system with Bose. I really like the nav now that they have updated the maps, and the Bose system isn't bad. I am happy to have it.
As for turbo vs. S, I think you'll find the S has plenty of power for most drivers. I don't ever feel that the Cayenne is too slow... it's an SUV afterall, not a sports car.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Settle for nothing other than a limited edition 2007 Cayenne.
You can retrofit the BiXenons...just ask TobyPennycuff for the DIY instructions
FORE !
FORE !
I agree the BiXenons are a must-have. There's no reliability factor there. As a daily driver I'm OK without the 20" wheels. 18 inchers offer a comfortable ride, and you don't worry about curb rashes. The 20" tires are much more expensive to replace; it all adds up given the short life-span of tires on this vehicle.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
And if you plan to tow a newish trailer that comes with an LED lighth package, ltc is a veritable fount of knowledge. In fact, I think he wrote a book entitled "Driving In The Dark" to document his experiences.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Larry's widow will be starting a company that offers both Maglites AND racer's tape, each color matched to factory Porsche paint. After all, looks matter when pulling into the paddock with a Cayenne tow vehicle.
And in order to be "green", for an additional fee, the Maglites can be upgraded to a Kinetic Energy Recovery System to help recharge the batteries and eliminate disposable alkaline batteries.
Rocky Mountain High
Is the standard sound system a MOST system also, or just the Bose system? Just curious...
IIRC, the Bose system comes standard on S and Turbo so you might be out of luck. Are you sure that audio problems reported are really Bose related (Bose sound quality/technology discussion aside). I was under the impression that many, but not all, of the problems were more Becker related (maker of the headunit). Then again, maybe experience is just rambling here...good luck.
I took the same approach as racer_65.
We bought a new 06S with steel springs but popped for the indash nav.
We had the ignition coils issue before 20K miles (perhaps we'll have to change them at each oil change...) but otherwise it has been quite dependable. I know, I konw, I have invited the curse upon me by posting this.
I think the only reason to get the air suspension would be if the steel springs are too harsh for your tastes. The only time it has really been an issue was when I brought my wife home form the hospital after a C-section.
I have never felt like our S needed more power and I appreciate the power of Turbos as I have them in my 996.
It sounds like the coils are the big problem. Is it a single coil or individual coils? If individual coils, does just one seem to go out at a time?
But overall, it sounds like there actually are people who like their Cayennes (and dont call them pigs, etc). That is a good thing.
-Dana
