No Sound from Radio
#31
#33
#35
While I have you, do you have any instructions on how to remove the pieces you have to remove prior to removing the side panel, i.e. C pillar trim, d pillar trim, etc.?
#36
Lacrosse finally ended and I had time to swap out the amplifier. Mudman you were 100% correct with the amp diagnosis. I have sound. Thanks again for your advice and the diagrams. Really wasn't that bad. I do have a bad Bose amp if anyone wants a paperweight.
#43
help
Hello All, let me apologize first for bringing this thread back from the dead. I am a small repair facility that purchased an 06 cayenne s and I am having issues with the sound or lack there of.
I get the dreaded message:
System Error: Navigation System, Ampliphier, Phone, Satellite Radio not available.
I have purchased an amp, a head unit and a nav dvd player. All known to be good.
I suggest culprit may have been the Nav unit because it would not turn on or open and when I removed it I found corrosion on the bottom and on the motherboard.
But after replacing all these items it still does the same thing. Any help would be greatly appreciated.
Thanks...
Thanks...
