DFI engines with valve carbon buildup?
Old 11-18-2009, 11:50 AM
richc
richc's Avatar
My '09 doesn't use any oil.
Old 11-18-2009, 02:55 PM
Slow Guy
Slow Guy's Avatar
I've gone 8700 mi. since I last changed my oil, I'm less than 1/4 qt. low and I drive it pretty aggressively. Pretty much the same consumption prior to my first change. I use ELF/Total 5w40. I'll be changing oil/filter and plugs this week. It has 48k mi.
Old 11-18-2009, 05:23 PM
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Wow bill just 48k on the clock.I am at 67k in my 06 now ;( . Have you had to do your water pump yet mine said ''bye bye see you later" pulling in the garage right at 60k!
Old 11-18-2009, 07:01 PM
Slow Guy
Slow Guy's Avatar
The Pepper is not my primary driver, I have the '97 M3 for that. Miles are much cheaper on the M3 and it's fun to drive. No water pump, no coolant tubes, no card. shaft, no...... yet! Only issues I've had is 2 inst. console modules and 1 tranny valve.
Edit: also had 8 coil packs done under warranty.
Old 11-18-2009, 09:51 PM
INURGRL951
INURGRL951's Avatar
oh ok that's cool same here not even a coil pack!
Quick Reply: DFI engines with valve carbon buildup?
