replace steering wheel?
Old 02-18-2009 | 07:33 PM
DR.G's Avatar
DR.G
6th Gear
Question replace steering wheel?
Hello Gents, a while since I post something, well........I need your help AGAIN.... How do you replace the steering wheel in a CS? where do I start?
Respectfully
Giulio
Old 02-19-2009 | 12:00 AM
pdxjim's Avatar
pdxjim
What happened to the old one?
Old 02-19-2009 | 12:55 AM
DR.G's Avatar
DR.G
6th Gear
I got an Olive/tan and I want to replace the old one.
Next will be the shifter.
respectfully
Giulio
Old 02-20-2009 | 11:10 PM
DR.G's Avatar
DR.G
6th Gear
I was told today at my Porsche Dealer that you need a special tool to remove the steering wheel airbag???? so...............they want me to go monday morning to the shop to replace my steering wheel........I miss the old time....where you can EASYYY replace steering wheels!
Any Idea on the "special tool"?
Thank you for your Help!
Giulio
Old 02-21-2009 | 04:00 AM
Gert's Avatar
Gert
The airbag is held in place by 2 latches.
There are 2 holes on the back of the steering wheel where you can insert a screwdriver.
I have an airbag here and will post a picture of the backside later today.
Old 02-21-2009 | 01:59 PM
DR.G's Avatar
DR.G
6th Gear
Gert, you are the best!!!!!!!!! and I think that I have to unplug the battery, right?
Thank you very much!
Giulio
Old 02-22-2009 | 04:01 AM
Gert's Avatar
Gert
You need to disconnect the battery if you want to remove the airbag.
Here is the picture, the red arrow shows where you end up when inserting a screwdriver in one of the 2 holes on the backside of the steering wheel.
You can even see the marks that I made, trying to get this one out.
The blue arrow shows where the airbag is attached to the steering wheel.
As you can see, you have to lever the spring wire to the outside and this on the 2 sides to unlock the airbag.
Old 02-22-2009 | 11:13 AM
Slow Guy's Avatar
Slow Guy
Gert, would something like a coat hanger wire with a small "J" on one end work for this?
Old 02-22-2009 | 11:27 AM
Gert's Avatar
Gert
I highly doubt this as you need quite an amount of force to move that spring.
I used a flat screwdriver.
Old 02-22-2009 | 12:43 PM
DR.G's Avatar
DR.G
6th Gear
Gert, that pic is fantastic! I will try today.One more quesion, do you think that i have to remove the steering protection to see the holes in the back? I could not see the holes.
Thank you for your help and time!!!
Old 02-24-2009 | 01:14 AM
DR.G's Avatar
DR.G
6th Gear
Gert, thank you very much! I did it!!
regards
Quick Reply: replace steering wheel?
