Gear Selector Removal
Moderator !x4
No thats it, its very simple. If you putting a new one on its quite simple also BUT if you want to put the original back on it can be quite trying
The new ones come with a little ring which hold the connector open while you place it on the shaft, when on you simply pull the little red plastic thingy off and your good. A small screw driver is a poor substitute for the red plastic thingy
Hope this is not to technical for you
Super Moderator
Needs More Cowbell
Needs More Cowbell
First the ECU, now the transmission.
Does the phrase "Don't Run With Scissors" come to mind.
Please, someone stop him before it's too late.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Hey, someone has to say 'Be Careful, You're Going to Poke Your Eye Out with that thing'.....
Besides, your previous Cayenne DIY experience....oh, never mind.
Hey, be careful! You're going to poke your eye out with that thing!
Did I do good? You rats closed the other thread before I could make any posts.
