do cayennes make loud ticking noise in engine bay
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I have heard some sounds in the engine compartment now and then, but nothing major and mainly when very cold or hot. Have it checked out anyhow.
Good Luck!
Good Luck!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Try using really complicated words....like lifter, tensioner pulley bearing, insufficient oiling due to clogged galley....
it sounds like there is knocking right under the plastic cover which says 4.5 and also there is constant knocking coming from the bottom of the engine----tuck--tuck--tuck---tuck---tuck----the sound can be heard from the wheel wells while suv is idling
The pump for the heating system is located in the drivers side wheel well - mine used to tick - they replaced it - it still ticked - then they decided it was normal. The lifters can be a bit noisey when cold or if you are low on oil - I would check your oil level.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I don't know about the undercar sound but the one on the top could just very well be your injectors you are hearing.
costas
costas
Does this describe the ticking you are hearing?:
https://rennlist.com/forums/showthre...ferrerid=34752
Rocky Mountain High
I've been out of town for a few days and unable to visit rennlist until now. I'm actually typing this on my iPhone. I forgot how entertaining the Cayenne forum can be.
the sound comes only when the engine warms up then it is just tuck tuck tuck and it is coming from the centre of the engine and also from the top---right under the 4.5 cover----i will try to put it on you tube and post a link as i really need advice before taking to the stealer on monday and to be told---------it is normal----
http://ca.youtube.com/watch?v=jKpGNIkV5MQ
there are 2 noises---one is the turrrrrrrrrrrrrrrrrrrrr
the other is the tuck tuck tuck
pls advise
pls advise
