coolant distribution pipe
had the CS in earlier in the year for an oil leak and while they were in the area had them replace the coolant pipes. This week we had another coolant leak underneath. Took it to the dealer, and they said the coolant distribution pipe is now leaking. Supposedly it is a cast iron piece just before the coolant pipes, and they have had to replace 5-10 of them this past year. Of course they are saying it is not a common problem from PCNA. But I have a call in to PCNA to try to get them to at least cover part of it.
anyone else had this pipe leak also? Seems pretty poor for a cast iron piece to start leaking on a 4 year old vehicle.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
I have not had this problem yet but others here have (99K on 2004CS in NH I believe it happens more in the hotter regions) . Should be able to find it on a search. Please keep us updated. The only leak I have is from the window washer fluid. Only leaks when full (very little) and drips onto the ground from under the drivers side headlight. Spooked me at first. Couldnt find it myself and dont want to pay someone (specially a dealer) to find it. Good luck.
I have the same washer fluid leak. The dealer said it's probably in the headlight washer area. I'm dropping it off with them this week.
