New Lowering module for Q7/Touareg/Cay $599
#31
No pic?
Anyway, why is this better than the links? I thought you could still raise the suspension one level with the links and the stiffness settings worked as normal?
The unit needs to be screwed in the kick panel while inserted on top of the aircompressor valve, then there's a on and off ****...
Put the car on loading level then turn the switch to on then it locks it on the loading level height... pasm sport/comfort/normal mode still works just fine...
but for height control you have to switch the unit off ,
The price is cheap but if you see the unit you'll say this is $600? LOL
But these are way better than those links.. this is a 5min install..
It does what it's suppose to do.. but the tire inflation warning light annoys me..LOLOL
amazing handling though.. he's not lying..
so i guess if youre trying to inflate your tire the air suspension cant be adjusted? so the unit triggers the tire air compressor? hmmm why didnt I think of that..hahaha
they should've called it something else.. like air susp defeat or ugly switch..haha
here's a pic... is this worth $600..![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
