Just did front brakes and rotors on my V6
And I have to say it wasn't that bad. The first side took about 90 min (including a run to sears for a Torx-50)...the second side took about 30min. New rotors, hardware, and Hawk ceramic pads. I'll try to compile a complete DIY from all the posts I used.
Were your rotors worn so far down they needed replacement? I will need new brakes soon but I was planning on just replacing the pads. I believe there is only minimal wear on the rotors. Curious if you measured yours or what?
Rocky Mountain High
Porsche recommends changing the rotors as well as the pads each time.
I did my pads a few months ago, and I measured the rotors. My rotors were all well within spec, so I only did pads.
Anyway, I had the dealer check the rotors. You can do it yourself with a brake micrometer. I forgot what the exact specs are. If I find them I'll post it with my DIY this weekend.
The rotors only run about $100 a piece. It's easy to do. And when you are saving $700 in labor by DIY, why not replace them.
