Tire Experience with Toyo and Yoko?
This is a great forum - I seached for steering vibration and found a wealth of info on the "steering shimmy" affliction. I have the 20" rims with a set of brand new Hankooks (not my choice) installed by the seller. I have had them balanced twice to no avail - still shakes badly. I have decided to replace these jewels with something more well-known.
I have learned from my searches that the Michelins do not typically suffer from the road-force imbalance issues. I have used the Michelins and Pirellis on my X5's, both were fine, but I read that many of the listers have had balance problems with the Pirellis.
My question is this - has anyone had imbalance issues with either the Yokohama Parada Spec-X ($146/ea) or Toyo Proxes ST(~$200/ea)? I have had good experience wit both these brands in the past (on p-cars) and the prices are much lower than the Michelins.
Thanks in advance for your feedback.
We have about 15kmiles on the Toyo ST's in 19" form. No complaints so far with balance and they're wearing well.. much better than the pzero oem's or the Michelins we replaced.
They're just now beginning to get a bit noisy.
We'll buy a 2nd set when these are gone.
well....
it doesn't exactly count, but i have had no problems with the parada spec-x tires that i am running on the FX45. they haven't gotten noisy like some of the tires i ran on the late, unlamented CS. be sure you check the load rating in your size.
I have Yoko Advan ST's and they are excellent. Great handling, good wear, low noise and agressive footpint. I may consider the Parada X-Spec next especially if there is good feedback but would likely stick with the Advan's if there's any doubt on the X-Spec
On my third set of Toyo's. The first two were 22's and current set are 20's. Also had Michelins in between. No vibrations whatsoever. For the price, the Toyo's can't be beat.
Another vote for Toyo Proxes S/T tires. I switched to 22" Toyos from the OEM Pirelli Scorpions after two road force balances and persistent steering wheel vibrations and severe cupping of the tires. The Toyos were sold with my Cayenne S, but got me through 2 Wisconsin winters (M+S rated), ran smooth as can be, wore like iron, and were also good performance tires. Though I got Michelin Diamaris on Sport Technos with my new CTTS, I am switching back to the 22" Proxes mounted on TechArt Formulas.
So how many miles do the Toyo's last? It seems to me if a set of tires cannot out-last the oil change interval, then it's not really satisfactory.
I have a question- are the brands and models of tires people are speaking of applicable to the 19 inch 275 series tires as well? We have the stock 19 inch rims that came with the titanium package, and while the P-0's have performed well, they are wearing much too fast.
-Andrew
-Andrew
Another recommendation for the Yoko Advan ST. I had them on non-pepper SUV's, and they have fantastic performance for such a composed and comfortable tire. The reinforced outer treadblocks seem to make a big difference toward scrub and wear.
I haven't tried the Yoko on the 955... and probably won't since the Toyo is doing so well. I'm figuring around 20 to 25 kmiles from these and will swap them out due to noise well before they hit the wear bars.
Well...the only tire setup that I had on my CTT that DIDN'T shake or shimmy was on the 20" Hankooks.
The stock Continentals and Pirellis were awful in this regard, and I refused to put up with the short life of the Michelins, which others have still had shimmy problems with too.
My Hankooks were fantastic...good grip, excellent life, quiet, and smooth...
Just my $0.02
Just my $0.02
I'm going to try rotating the Hankooks (front to back) and see if there's any difference. If not, I'll try a pair of Toyos on the front and see if that fixes the shimmy. If that works, I'll replace them all and put the Hankooks for sale. Maybe they'll work for someone in a non-Cayenne application (..or find some 20" rims for the wife's X5, hmmmm....).
Maybe it's because the cayenne is the first new car I ever bought, but the balancing of the tires/rims and driveline is amazing, although I'd imagine gets rougher as the miles/years and number of pot holes hit pile on...
