Sweet iPod Dock
Pepper Bartender
fixed rear window dripping continuously.... nooooooooooooo..
fixed rear seat "cowboy" belt buckles in new cars...... noooooooooo.
fixed vibration/shimmy in the steering column...... noooooooooooo.
fixed towing !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --- whoops.. not fixed yet....
SECOND ONLY TO (#1 best answer)... the key fob range being expanded to 50 feet from .5 feet!!! DING!
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
There IS in fact nothing to fix related to Towing, LED's and !!!!!!!!!!!!!!!!!!!!!!!!.....this is direclty from PCNA Legal.....it works EXACTLY as designed.
We now return you to your normally schedule forum banter
Super Moderator
Needs More Cowbell
Needs More Cowbell
i'm thinking about getting this ipod set up in the cayenne, i was wondering if someone has this and what are there thoughts about this setup?
would u recommend it ?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Moderator !x4
Most devices added to MOST network must simulate another device to work. Porsche (Becker) software in the car is not flexible or accessible.
In this case the mObridge unit simulates the CD Changer on the MOST fiber optic ring and uses the capabilities of the CDC Software in the headunit to control things.
The MOST system only expects to see 1 CDC on the network and while you could connect 2 there will always be a conflict, most likely based on which unit boots first.
The outcome would be sometimes you have a CDC sometimes a mObridge unit but never both at the same time.
There are probably ways around this, either by bypassing one of the units at startup. mObridge has a bypass setting which can be used to make the unit "go away" when a dealer tester is hooked up. You could not do that with the CDC as the unit has to be powered to pass the signal and that was not a feature built in to it.
I removed my CDC and sold it on EBAY, not one regret as the iPod works so well I could not imagine wanting to put a cd into the changer anymore.
Pepper Bartender
![order](https://rennlist.com/forums/graemlins/order.gif)
Yes to the loss of the CD changer in the rear compartment BUT I don't miss it BECAUSE.. the single CD on the PCM itself will still work. So on the rare occasion, that you have a new CD not converted to your iPod and/or a CD that a "guest" wants to play and/or a CD audio book from the library etc., you WILL be able to still enjoy CD's --- but you'll have to eject and play them one by one!
Ordering the mObridge today. Merry Christmas to me.
Super Moderator
Needs More Cowbell
Needs More Cowbell
This allowed for all kinds of playtime......
Or at least that's what I read on an internet forum.....I know, you can't believe everything you read.
