Coils
Moderator !x4
Coils
Can someone post a procedure for replacing coils, I have a feeling this might prove usefull to a lot of people. Oh a procedure that does not break the strut.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Why would you ever have to replace the coils? There's nothing wrong with them, remember?
On a SLIGHTLY more serious note, have you checked Loren's site?
It's at times like this that we miss 'Wingless'.....Forum Keeper of the Cayenne Factory Manuals and Wiring Diagrams.
Wonder what ever happened to him?
Originally Posted by 99firehawk
there isnt actually anything wrong with the coils...............
...they are just cracked and PASS electric current in a WRONG area...
...here is again old discussion thread:
https://rennlist.com/forums/showthre...3&page=1&pp=15
...and check/replace procedure in pics:
http://gallery.rennlist.com/cayenneg...oil-Inspection
...parts used for CayTT 04:
8 * 999-170-218-90 Spark Plugs
8 * 948-602-104-01 Pencil Coil
...PIWIS shows NO error code for defective coils/plugs
...parts cost:
plugs about 50-100$ for 8
coils about 100-150$ for 8
...dealer labor asking about $650, if out of warranty...
Thanks to Wingless, Mudman2 and all contributed members from this board.
OZRacing
Moderator !x4
Brilliant, thanks ozr for the compilation, I had forgotten those excellent pix by Wingless. Its the passenger side Torque suspension member that gets broken by the dealers a lot of the time when they change the coils. (check your bills, those who have had it done under warranty)
Anyone got anything to add ?
I will place across with Loren when done.
Super Moderator
Needs More Cowbell
Needs More Cowbell
There is NOTHING wrong with the coils.
The logic is used is identical to the "There is NOTHING wrong with "!" Check Trailer Lights"......and "There is NO hesitation in a Cayenne and it has nothing to do with the ECU/TCU"......and "Your rear hatch didn't open all by itself while you were driving"......and "No, that is NOT a vibration you feel in the steering wheel when driving".
Cayenne owners just often complain about issues that don't exist.....just "shut up and drive".
Super Moderator
Needs More Cowbell
Needs More Cowbell
P.S.
Does anyone know what actually happened to Wingless (an original member of the alpha/beta survivor 'test group')?
Did he cut off one of his limbs with a sharp edge of paper from the Workshop manuals and is no longer chained to his Cayenne?
You know when the engine start lurching when having bad coils, could that put more stress on the drive shaft?
Just wondering because it seems really poor quality to have to be replacing a drive shaft @ 48k and the car is lady driven and not even pushed hard.
Super Moderator
Needs More Cowbell
Needs More Cowbell
IIRC2, it was covered under warranty as a good will gesture.
This is of course long after 'The Great Cardan Shaft' TSB/Recall, back in the dark days of the alpha/beta units.
Pepper Bartender
Originally Posted by ltc
IIRC, MadFox had his cardan shaft replaced very shortly after going naked. IIRC2, it was covered under warranty as a good will gesture. This is of course long after 'The Great Cardan Shaft' TSB/Recall, back in the dark days of the alpha/beta units.
Wow.. that was way too much thinking.... pass the Rex please.
Pepper Bartender
