Stuttering on acceleration
I have a 06 **** with about 1300 miles. Over the last 100 mile or so i have noticed a "stuttering" on mild acceleration, as if it is misfiring. No noise, just lack of power. Thought it was the gas, no difference with brand change. 92-93 octane
Took to dealer - no fault codes found, reprogramed the DME ? - will pick up tomorrow to see if better
Search these posts, and it seems this sounds like a coil issue, but at such a young age?
Pepper Bartender
Coils can be old, young, medium aged .... and still be bad... but I'd also check the Fuel Pump and/or the sensor.. newer cars have the modified coils (or so I thought)... cue ltc...............
Pepper Bartender
Originally Posted by ltc
Modified....like the rear window microswitch rev 3 and rev 4?
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Originally Posted by MadFox
but when I do open/use it .. (a) it is a pain in the *** for it to register closed.. (b) only takes a few slams! thus, (c) I now only open the entire rear hatch. but, (d) this is still the ONLY problem to date --- and probably just needs adjustment...: ![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
lic265 - Try a bottle of Techron System Cleaner. It's not going to hurt anything and it might cure your problem. You will know if it works before you burn a tank of gas. If it clears up, start using Chevron all the time.
Pepper Bartender
Coils
Dammit Jim... er, ltc... you'd think... cue the star trek theme music.. we've been where they never been before!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Glad to be a new member of the "Coils Club" - but only after they changed out my spark plugs did my problem start.
So - Tuesday we see what happens...
Put a bottle of Techron in the tank - no better
Still feeling like it is misfiring or "stuttering " under mild- moderate acceleration
Any ideas before i go back to the dealer?
