Cayenne v6 mods
Cayenne v6 mods
Just curious if this engine is starving in any way like an Audi A4 for example. Any engine mods which produce significant returns? Not looking to Supercharge. ECU remapping for example.
Thanks.
Thanks.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Thanks.
Thanks.
It's a NA engine, there isn't much to be gained.
Potential power gains on a naturally aspirated 3.2 liter engine are minimal. 250hp from 3.2 liters is already pretty good @ 78hp/l
That's more hp per liter than a Z06...
Anyways... you can go 250hp>350ish with a VF Engineering supercharger for about $5000.
Or trade in your V6 and $5000 cash (cost of SC) for an 08 Cayenne S... and a little higher p'mt.
Super Moderator
Needs More Cowbell
Needs More Cowbell
OK, I assume that means no although I am not sure what you mean by it's a NA engine therefore there is not much to be gained.
It is fairly simple to increase HP in a forced induction engine, usually by remaping the DME to increase boost; re: buying a chip.
You can then go further by adding larger turbos, exhaust, etc......Stage 1 to Stage 4....you can double the HP of the engine.....of course at the expense of higher running temps and less engine life (hey, nothing is for free). PAG normally designs in margins in most of their engine internals and drivetrains.
In a normally aspirated engine, this is MUCH harder to do so adding a 'chip' adds ~10% gain in HP....maybe. In the case of your Audi V6 engine (with Porsche "designed" intake runners), there is little internal margin.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Yeah, this V6 is a turd. I am going to an S by tomorrow's end.
Thanks all
Thanks all
Remember, the grass isn't always greener.......
Apart from that, good luck.
