Porsche coolant the same as Audi V8 coolant?
Old 10-31-2006 | 12:53 PM
yetis's Avatar
yetis
Default Porsche coolant the same as Audi V8 coolant?
Just wondering as I know this guy, who pulled the wrong hose on his CTT and dumped a bunch of coolant out of his car... So, in a fit of panic, he added some coolant for an V8 S4 engine. Seems to be working, but he "thinks" the coolant temp now seems to flucuate a bit more. That said, he is also a little sensitive to the issue.
Is there an easy way to drain the coolant, so that he can add the over priced Pcar stuff to ward off dealer issyes, or is this nothing to worry about?
Friend of a slow DIYer...
Old 10-31-2006 | 04:34 PM
User 4221's Avatar
User 4221
Audi uses a special coolant that, when mixed with std. Prestone-type Ethelyne Glycol, will turn to sludge.
I don't know what the Cayenne requires, but he had better pray the Cayenne doesn't use E-G.
Old 11-01-2006 | 09:44 AM
mjw930's Avatar
mjw930
He could crack open his manual and see what the coolant spec is then go down to the local AutoZone (or whatever) and buy the proper coolant...... It never ceases to amaze me what people will do to their $100K vehicles simply because they are too lazy or too incompetent to RTFM.
Old 11-01-2006 | 09:50 AM
yetis's Avatar
yetis
I never ceases to amaze me how people spew useless advice/commentary on the internet. I guess making the people around them miserable all day, isn't good enough...
Thanks for the advice, next time, keep it to yourself.
BTW, he did and he also called the porsche/audi head of service that said it would be fine. Just thought he would get a second opinion....
Old 11-01-2006 | 03:47 PM
Rider1's Avatar
Rider1
So you're saying that the "advice" here is better or would cloud the expert advice of the porsche/audi head of service? Or what the owner's manual says ????
Jeez!
Dave
Old 11-01-2006 | 05:39 PM
99firehawk's Avatar
99firehawk
no offense to the head of service, but do you really think a suit and tie guy is the one to ask for technical information.
Old 11-01-2006 | 09:46 PM
mjw930's Avatar
mjw930
Why didn't you post that information in the first post.
You baited us here with incomplete information in the hopes you could get tertiary confirmation of a fact you already knew to be true.
As for this:
If my pointing out that all you really needed to do was is considered useless then what do you consider a thread about a non existent problem........
Sorry if I wasted YOUR time and BTW, the people around me are quite content, thank you very much.
Old 03-31-2022 | 01:46 PM
garthg's Avatar
garthg
Default 2022 Spec is G40 or VW G12++
I'm adding to this old thread, since I didn't find an answer elsewhere.
I looked deeply in the manual of our 2022, page 277, coolant is specified as Glysantin G40 or, alternatively, VW G12++.
VW doesn't sell G12 anymore; they've moved on to G13. FCP Euro (and the dealer) state that G13 is backwards compatible to G12.
The color is the same. I would assume that VW G13 is compatible with Porsche G40.
Old 04-01-2022 | 10:38 AM
brett968's Avatar
brett968
You will be perfectly fine adding G13 to your current mix as long as you know that factory coolant was used previously (and not some random coolant from the local auto store). Technically this chart is VAG focused but it's applicable to Porsche:
This is what I've used recently in my Audis and Porsches: https://www.fcpeuro.com/products/aud...3a8jm1#fitment
A big advantage of G13 over the earlier coolants is that it is glycerin based instead of glycol based and has greatly reduced toxicity, making it safer to keep in the garage for those who have pets (and little kids).
Old 04-02-2022 | 06:11 PM
garthg's Avatar
garthg
I just checked the label on a bottle of VW OEM G13. It contains ethylene glycol. Perhaps it also contains glycerin but ingredients other than glycol are not specified.
Old 04-02-2022 | 11:30 PM
phatz's Avatar
phatz
It is odd as I recall reading that it was glycerin based ...but surely doesnt read as that
Old 04-03-2022 | 09:52 AM
garthg's Avatar
garthg
Per Valvoline, G40 is 90% ethylene glycol. I presume the other 10% is anti-corrosion agents.
The VW MSDS is for the 50/50 ready-mix, so of course the figure is half. (You're paying VW or Porsche prices for water).
Quick Reply: Porsche coolant the same as Audi V8 coolant?
