Post your repair / warranty list here
#301
I'll take it all back...
"Based on my read of the Cayenne Maintenance & Repair string, one can safely assume that reliability on the Cayenne, may just be a crap shoot. Some people get lucky, most others aren't. At least that's my take away...and if you still need one, I'll sell you mine...all the known "soft spots" have been replaced such as drive shaft, cooling pipes, LED display...misc items falling off such as the passenger side mirror, the rear windshield wiper blade and have new tires, brakes and rotors."
OK, we have had the car about 8 months...and 15,000 miles. It has really grown on me/us....love the performance (acceleration) and handling. Driving the car is a blast, and the Tiptronic 6 speed, great close ratio gears. I'd love a new one for Bluetooth and some other modern incites, such as a Back Up Camera.
#302
The V8 Porschephile
Warranty work since purchase back in 2010 ('09 GTS):
- High pressure fuel pump (recall)
- Heater blower motor (squeal at low speed)
- Transfer case (jerking at high speed)
- PCM unit (to solve issue with audio AUX input)
- Passenger seat rails (shaking)
- Horns (non-functional)
- License plate lamp housings (corroded)
- Rear trim plate on bumper top (de-lamination of SS trim)
- Exhaust sport-mode transfer linkage (rattling at start-up)
- Fuel injector - Entire LH fuel rail (missing on acceleration)
- RH passenger window switch (rubber coating de-lamination)
- Rear tailgate replacement (premature corrosion)
- RH front & rear passenger doors (premature corrosion)
#303
Received 1,141 Likes
On the 2011 Turbo... bought with 58,000 miles on it. Currently 63,000 miles. No unexpected repairs. I did end up with a fairly major repair (R&R of the engine, cylinder heads) due to a mishap when the Porsche dealer was doing WC-22 at my expense. Luckily the major repair required was at their expense. Other than that - tires is about it. Everything works nicely, including the Pano roof.
#304
#306
https://rennlist.com/forums/porsche-...l#post13803808
#307
2004 Cayenne, 125,000 km. Shipped by train from Vancouver to Eastern Ontario
lower control arms
rear hatch struts
6 AC servos
coil set 1 installed so far
Jimi fix on Cardan shaft support bearing
130,000 km
right front CV boots
winter tires and rims
flushed power steering fluid
changed brake fluid
replaced battery (under seat) rear battery not replaced
156,000 km
coolant reservoir
discovered aluminum coolant pipes already installed
spark plugs and rest of coils -- discovered only 4 of 8 eBay coils would actually work.
lower control arms
rear hatch struts
6 AC servos
130,000 km
changed brake fluid
156,000 km
coolant reservoir
#308
lower control arms
rear hatch struts
6 AC servos
(11 physiotherapy treatments for pinched neck nerves from working under the dash on those servos)
130,000 km
lower control arms
rear hatch struts
6 AC servos
130,000 km
you didn't Remove the dash board to change the actuators?
#309
You mean there's another way?
Up through from below. I had bought a set of seven off an '08 just in case. The ones I removed weren't burned out, but the newer ones seem better engineered, so I replaced them as I went. The heat and modulated air conditioning feel good.
Nasty job.
https://rodcroskery.wordpress.com/2016/09/18/ruby-yoga/
Update: 21 March, 2018
Heat and air worked well all winter after a recharge in November.
Nasty job.
#310
Just had Valve Cover Assembly done at 128k. The engine was misfiring/running rough. Thought it might be a coil pack issue but those were replaced at around 114k. Other minor items addressed: ashtray stuck, new battery under driver's seat, defroster issue and a couple of headlight bulbs.
#311
https://rennlist.com/forums/porsche-...-s-normal.html
#313
Adding the repair items for my 2008 Cayenne S (approx. 130,000 miles now):
1. Replaced engine cooling pipes (leaking)
2. Replaced all ignition coils (misfire)
3. Replaced high-pressure fuel pump (rough idling)
4. Replaced oil separator and engine gaskets (sticky start)
5. Replaced driveshaft (vibrating)
6. Replace drive belt (cracked)
7. Replaced catalytic converter bank 1 (failed)
8. Replaced starter (failed to start)
9. Replaced rear center brake light (intermittent failure)
Not a very great reliability record IMHO.
#314
The 958 no longer has the two speed transfer case but still uses a transfer case to shift power between the diffs. As for symptoms,
#315
Replaced Transfer Case to Fix Uneven/Slipping 2nd-3rd-4th Gears Shifting
I just had my transfer case replaced and a new vent line installed on my 2012 Cayenne S at 52k under CPO ....They first tried to address this via a software update, but it didn't solve the problem. The SA told me that this has been an increasing issue on the 12's, caused by precipitation getting into the transfer case from the vent line which causes the slipping (which is worse when the car is warm). They replaced the transfer and installed the new vent line which apparently is now located ABOVE the case to avoid any water/precipitation entering the transfer case. Here is the thread on the discussion that I posted with the symptoms and the resolution last week:
https://rennlist.com/forums/porsche-...cayenne-s.html
I got it back on Friday and it's working perfectly ('cause I've been beating on it all weekend ). And here a pic of the write up from the P Dealer (Loeber Porsche in Lincolnwood, IL) who were really great on this CPO work
