Towing a Travel Trailer
7th Gear
Hello all-
I am ooking at getting my wife a Cayenne S. I tow a Ski Nautique and a 23 foot travel trailer (the Nautique gets pulled over the pass Washington State passes about every other weekend). My question is how will the Cayenne tow these 4000-4500lb items over the pass?
And, I need to deal with brake controller and light hook-ups? I have read horror stories about the lighting system?
Any info is appreciated, our current Tahoe just is not that fun to drive anymore when I get out of the S4 or 914/6.
Brett
Brett
UH OH! ! ! ! ! ! ! !
Brett, do a search and you will find plenty of info. You could just search for (!) and probably find what you want too.
I'm going to take cover now....
Yep, duck and cover are in order....
Well actually it's not that bad. You really just need to look after these few issues
1. Don't use LED lights but if you must then purchase the U-Haul LED load balancer and run it in-line or wire it into the trailer's lighting system
1a. Don't try to drive too many lights as in some of the car haulers that have about 20 running lights
2. Use a standard, analog brake controller. Wiring documents and parts list can be found with a simple search
3. Make sure your towing controller is set to the USA option
4. If you have a choice get PASM (air suspension). It should be standard with the tow package IMHO
5. Although many here tow with the V6 I would stick with the S or CTT considering the size of what you are towing.
That's about it and you should have no problems.
See Lewis, I do listen
Cows-4-Rent
I have towed with the PASM and without and there is no way I would go without. Regardless of where I put the car in the trailer, I have to pull out the floor jack to raise the rear enough to get the tongue support on/off. The truck sags severely and really lightens up the front end which is simply not safe or efficient.
The PASM cures all of these ills and assists in hooking/unhooking the trailer to the hitch.
I know the trailer lights have caused some headache but personally, I do not think it is a big deal to pull 3 of 20 bulbs on the top/front of the trailer for all the lights to work. I know, blah, blah, blah, but Lewis' issue is the ONLY one that I have heard of that is so severe. Mine is on '04 and a simple fix for the Prodigy controller and all works fine. I love the truck and feel that it is a top-notch, midsize tow vehicle.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by JPhillips-998
I know the trailer lights have caused some headache but personally, I do not think it is a big deal to pull 3 of 20 bulbs on the top/front of the trailer for all the lights to work..
Again, the system works as designed, it was simply designed under incorrect assumptions regarding the application of in vehicle bulb diagnostics to a trailer lighting system whose configuration, by design, can NOT be known a priori.
BTW, there have been other (documented) issues of "so severe".
Hypothetically speaking, perhaps the reason you don't hear it often is due to a legally binding non disclosure agreement between the parties involved once the issue is resolved.
Of course, I would have no knowledge or experience in an area such as this.....
