Tequipment Option - Thicker Padded Leather Steering Wheel FYI
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
JIK anyone was interested in Tequipment's thicker padded steering wheel in leather - with heated option (955-044-400-01-5Z3), It just arrived at my doorstep today and I really Luv it! It is slightly bigger than the stock one and is much more comfortable for the grip. If I am not mistaken, it will be the leather wheel that will come with the Turbo S standard. The Turbo S's that I have seen have all had combo leather and wood wheels without heat so I cannot verify.
Nice added option to have on any Cayenne though!
Have not installed it yet. (It is about 10mm-12mm wider than stock from outer edge to outer edge and is about 10mm thicker in grip circumference) On the "to do list"!
April 19th - GIAC tuning
April 21st - Steering wheel, Smoked tail lights, Brake fluid flush, new plugs, coils pulled and checked, new lower rear plastic valance, air intakes put on, check alignment, check break pads with possible change, and possibly a catback sport muffler too.
Bypass pipes on and new diverter valves in already.
I will post a few new pics on that site once all is completed.
10mm diameter not radius - so split 5 on each side is such a negligible difference visually and physically (plus I like when the wheel grazes my groin, that is why I make so many U-turns
I
didn't want a "monster truck" steering wheel either and this is surely not the case!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Kooser,
I just installed the catbypass pipes on my 04ctt and 22' Wheels and Tires!!! Wow it sounds great!! I will send pictures in ASAP. Let me know after you do the GIAC. Are you going to Dyno before and After?
Originally Posted by JoJocayenneturbo
Kooser,
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I should have dynoed the car before any changes. Never thought to because Alex911s kindly demonstrated the appreciable gains on his beast.
Here is a picture of the thicker wheel on Suncoast website, but order from Sunset it is much cheaper. I think I had put the new thicker one on my old thinner one, and they had the same diameter.
http://www.e-partssales.com/miva/mer...955GEN2inttrim
Super Moderator
Needs More Cowbell
Needs More Cowbell
Just call me Pops
I honestly miss the dude......
but three years later, is it safe to assume that his wife pulled a "Mrs. Tiger Woods" and beat him with that exhaust? To death! This is the only explanation to his abrupt departure from RL that I could think of
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
A Cayenne can drive people to do all sorts of things...hey, look what it did to Larry....not that I'm complaining, I ended up with his widow
