Anbody replace their CTT exhaust system?
Just curious if anyone has replaced the exhaust system (Rinspeed) or are most folks just going with the cat bypass pipes?
thanks,
james
thanks,
james
Just the rear cat bypass pipes for me. I've seen a few cool looking systems but probably won't bother. The only one I thought was really trick was one out of Japan and made entirely out of Ti. Probably saved about 50 LBS.
Talked to someone the other day who had replaced the system with the factory Turbo S exhaust and ECU upgrade. I believe he claimed it was about $2500 for everything is factory waranteed and gives turbo S power.
Originally Posted by R68
Was this done by a dealer? I can't believe they would flash the ecu and replace the exhaust for so little $$$. I would think the exhaust cost at least $2000.
Don't forget this would be using the stock IC's which may or may not be an issue and you don't get the bigger brakes and 20" technos.
He did say it gets a bit squirrely under WOT. This may be a bit too much power for the stock brakes.
