Squeaking Front Door Lube Point?
I've recently noticed a squeaking noise when opening the front doors on my 18 month old 2004 CS. I assume the fix is some wd-40 on the hinges and there is no need for a door hinge realignment or adjustment by the dealer.....but I did a quick search on the forum to see if this is a known issue and didn't come up with anything......is there anything known to the group that I missed?
Thanks,
--Bob
Thanks,
--Bob
On my 03 S, I had a similar problem and took it to dealer. They replaced the hinge. Might want to have the dealer look at it.
I had the same problem but only with the driver door and after 30K. I just lubed the door with Prolong lubricant and away it went. I never visited the dealer with the issue. This was 2 months ago. I also lubed all of the other doors as well JIK.
Mine had a distinct grinding associated with the noise. The service guy said immediately it was a bad hinge.
Thanks for your replies.
I have to take it in to the dealer in 3 days anyway to have the key remotes replaced (they were working fine but I had the oil changed at the dealer recently and they checked for service bulletins and replacing the remotes was on the list) so I will have the door hinges looked at and let you know the results.
I talked to the service writer about this yesterday and he said he had not seen a problem here and assumed it was just a lube issue but I don't think they see a high volume of Cayennes; the tech who works on it is very good and I am reasonably confident that if there is a mechanical issue he will be able to spot it.
--Bob
--Bob
You might also check the rubber boot joining the door to the body, which I believe protects the wiring harness. I had a creaking on the driver's side rear door that I first thought was the hinge, but then I realized it was actually coming from the rubber boot. A little Vinylex or silicone treatment on the rubber and the creaking went away.
Update: the tech checked the hinges and straps and applied lube and all seems ok now.
Except for the damn remotes.
The new ones have upset whatever programming I had done in the comfort menu and now I've got to figure out what I did and re-do it so it works the same.
Grrr.
Grrr.
I spoke too soon. The creaking/squeaking is still there or has returned.
Maybe it was too loud outside when I listened and thought it was fixed, but I sure can hear it now in the quiet of my garage.
I think I'm going to try spraying something on the rubber door seals and see if that helps.
It's back.
Of course I can't remember what (if anything) I did to stop it last winter, and if I found a cure I didn't post it. My bad.
I've been by the dealer for a couple of other things twice in the last 2 or 3 weeks and each time they have sprayed the doors with lubricant (not WD40) and it has not solved the problem.
On closer listening in the quiet of my garage it sounds like the squeak is coming from the lower part of the front doors when opened and closed.
I'm reluctant to use WD40 because (despite what they say on their website) I'm afraid it will damage the rubber seals and wiring harness cover. I've got some 303 protectant spray but I'm not sure that's the right stuff either.
Anyone had any updated experience with this issue?
Thanks,
--Bob
Thanks,
--Bob
