Front Brake Pads DIY Instructions
Old 12-24-2005, 04:29 PM
mudman2
Moderator !x4
mudman2's Avatar
Default Front Brake Pads DIY Instructions
First, let me say that when I took the pads out the rotor looked
fine and although I have slotted drilled rotors to put on I did
not see the point in wasting them they will go on next time.
Total elapsed time including jacking, wheel removal and the job
itself was 90 minutes
A single bolt hold the pad retaining pin in place, as usual with
fluid locked bolts tighten a fraction to break the seal and then
remove as normal.
Leave the bolt in couple of turns and tap the end to start the
pin on its way through.
I used a broad flat screw driver as a drift to knock the pin
through and a mole grip to pull it through. Its a pain to get
through I warn you.
Once the pin is out, break the sensor wires , its easier.
Use a driver to lever the pads out.
Removing the old sensor cable was hard so breaking the connector
seemed easier. Route the new cable to the connector and behind
the little loop on the brake nipple rubber cover.
The sensors clip in with the thick part pad side.
To get the new pads in you will find that depressing one of the
pistons is easy, the second ok the third forces out the other 2.
I found the easiest way was to depress the first 2 and then slip
the pad in, with the pad bkocking the first 2 depress the third
and push the pad into place. Its not hard just fiddly.
You really need three hands to put the pin back through. The best
way is to depress the pad retaining spring and tap the pin
through, for the last part you will need to push the pin itself
into line.
Dont forget to get blue loctite for the pin bolt and brake grease
for the back of the pad.
Old 12-25-2005, 12:21 PM
TimC.
TimC.'s Avatar
Awesome detail thanks!!!....so much trust in that Craftsman jack with your legs under there...LOL
Old 12-25-2005, 12:51 PM
skl
Official Wednesday AM Red Bull F1 test driver
skl's Avatar
A Christmas Eve project eh? Had to get out of the house didn't you??
Isn't year old black brake dust just wonderful...did you replace with OEM pads or something hopefully with less dust? I'm thinking of Rotex Gold- anything but those damned OEM dustbusters!!
Old 12-25-2005, 03:00 PM
mudman2
Moderator !x4
mudman2's Avatar
What you cant see in those shots are the axle stands holding up the car I am no fool !
I put Brembo pads on, not low dust. Rejex Rules.
Old 12-25-2005, 10:11 PM
LVDell
LVDell's Avatar
Thanks Michael! BTW, did you use anit-squeal shims on the back of the pads? I use them on my 996 pads but have not done my Pepper yet (only 5K miles so far).
Old 12-25-2005, 10:41 PM
mudman2
Moderator !x4
mudman2's Avatar
No they did not call for them I just used the grease.
Old 12-26-2005, 12:12 AM
LVDell
LVDell's Avatar
The grease? Any pics or description?
Old 12-26-2005, 09:46 AM
mudman2
Moderator !x4
mudman2's Avatar
Just regular pad anti squeal grease, you smear it thinly on the back of the pad. Any auto parts store has it just ask them.
Old 12-26-2005, 10:59 AM
broskinny
broskinny's Avatar
You have the brake pad warning sensor harness routed on the inside of the pin instead of the outside.
Is it going to get pinched against the spring plate as the pads wear?
Old 12-26-2005, 11:35 AM
mudman2
Moderator !x4
mudman2's Avatar
I spotted that when I was finished so I re routed them but the camera battery was flat by then. Well spotted !
Old 12-26-2005, 11:59 AM
MadFox
Pepper Bartender
MadFox's Avatar
Bravo! A truly smart guy! Great Documentation... for those PROPERLY equipped and with axle stands (safety first) your pics and steps are great... For those not with the "proper tools"... it confirms that at least for this guy --- uh-hum... I'll let the "professionals" do it!!
Old 12-27-2005, 09:22 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Question
Hold on a second, I'm confused.
56K miles and I've never done the brakes.
(for that matter I've never opened the hood or done anything else....).
disclaimer: skl DID guilt me into attempting to wash the wheels after 2+ years of ownership....I ran out of Brillo pads so I didn't finish.
Are you guys telling me I actually have to have MAINTANENCE done on this thing?
I was just under the naive assumption that I would drive it until it dies
Old 12-27-2005, 12:17 PM
Truble10
Truble10's Avatar
Nice description & pics. Looks like a little more work than the old "big reds".
Old 12-27-2005, 06:06 PM
Romantic911
Romantic911's Avatar
Exellent ..thanks V.much .. and i appreciated if you carry on with the rear brakes
Old 12-27-2005, 07:36 PM
mudman2
Moderator !x4
mudman2's Avatar
Will do when required.
Quick Reply: Front Brake Pads DIY Instructions
