Tire Goop Kit Tip
Tire Goop Kit Tip
If you do not have a spare, tire then you have the goop kit that contains a bottle of goop, a spare tire valve, and a valve removal / installation yellow plastic tool. This afternoon, I used the yellow plastic tool to remove a valve, and this plastic thing broke. This could be a big problem if you need a reliable tool at the side of a road. I threw the yellow one away, and put a metal one that doubles as a cap in the kit. You may want to do the same.
