Check Dipped Bean x 2
"Check Dipped Beam" warning comes on, one headlight is out. Turn off car, turn back on, both headlights will work again. This is what was happening.
Had this problem fixed last month.
Yesterday it started happenning again!
Anyone else had this issue?
TIA!
TIA!
I have had it go on and then the next time I start the truck, everything is normal. Is bill gates involved with our truck's computer??
Today I had new tires installed and I turned off the air suspension when I took it to the tire mounting place. After the install, I left and noticed (warning was showing on dash of low air pressure) that the air was low in all tires so went and filled up as specified. Drove the truck home with no warning showing. Then went to dinner and had a fault showing on the dash on the air suspension requiring "workshop visit". I tried restarting a couple of times and it stayed on and I could not raise or lower the suspension. After dinner came out and everything was normal, could raise and lower things. Must be a Microsoft "issue".
Super Moderator
Needs More Cowbell
Needs More Cowbell
Had this problem fixed last month. Yesterday it started happenning again!
TIA!
TIA!
How did your dealer repair the issue?
There are issues regarding the fit/quality (remember, profit is everything with this vehicle) of the bulb holders. They are prone to allowing for a loose mechanical connection between the bulb contact(s) and the housing contact(s), which leads to increased resistance (and/or arcing), which leads to heat, which leads to mechanical deformation (or in worse cases melted plastic), which repeats the cycle and you end up with a poor electromechanical connection, which trips the integrated bulb check diagnostics .... i told you I was going to skip the long boring technical details...this is just the Reader's Digest version.
If the dealership merely cleaned the contacts on the bulb holder, it's likely to have NOT fixed the problem. The contacts need to be mechanically inspected and bent back into the correct locations and/or have the bulb housing/holder replaced.
Once that is done, you should be all set.
ltc is right on about the bulb issue. One addendum that may be beneficial. This problem can be compounded by loose mounting plates for the headlight unit itself. There were a couple of revisions to the plate and the fasteners used to secure the headlight unit. I've seen a couple seemingly erroneous light warnings (directional, dipped beams, etc) cause by poor electrical connections caused by the unit being able to vibrate more than it should. Something to have the dealer techs look into.
Hey Gang.. Sorry for the duplication on this topic.. but i'm stuck.. Check dipped beam on the drivers side.. Took the assembly out, made sure all the contacts were secure.. and still flickering.. I find it odd that if I wack the lens, it sometimes comes on.. so I thought it must be something loose.. and appears to happen more in cold weather.. thoughts?
Also, any idea on how to change a right front fog light assembly? I have a 05 Cayenne S (no side vents). Hit a snow bank and busted one of the attachements. Is my only option to remove the entire bumper? if so, any thoughts on I how I go about it?
thx!!
ps. I do have the rear mounted spare, I'll post pics soon.
thx!!
