Cayenne hesitation....learn to live with it
#31
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by mudman2
You crack me up !
#32
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by RJay
I'm afraid to ask...
If you have sufficient PeptoBismol in the house, are not allergic to shellfish and do not get motion sick, please feel free to continue reading at your own risk......
There are some "issues" with the integrated bulb detection circuitry built into the Cayenne as extended to the 7pin Pollack trailer connection.
In a nutshell, depending on the type of lighting load you present to the Cayenne at the 7pin connector, you will end up driving around with a "!" Check Trailer Lights warning permanently emblazened on your dashboard. Of course when you really DO have a trailer lighting issue, the warning will disappear and you will drive at night with no trailer lighting.
LED's appear to be out; my 20' Cargopro enclosed aluminum (purchased from Atlantic Coast in Charlton...good guys) is full LED. Myself and JFScheck have LED trailers, same problem.
Too many (how many is too many, Porsche doesn't know) standard incandescents can do the same thing; ask skl, he has an 18' ATC aluminum enclosed with standard incandescent and he has to unscrew a few running/marker lights....otherwise his headlights go out in response to the 'fault' condition.
On a positive note, prior to the first recall/TSB/service action for this condition (W406 IIRC), you would get the BEEP "!" Check Trailer Lights message EVERY SINGLE TIME YOU STEPPED ON THE BRAKE! So, things have improved.
BTW, NONE of this is covered ANYWHERE in the Porsche sales or service documentation, NOTHING in the owner's manual...not even in the 'Warning Display Messages' section. Nada, zippo.
In doubt, don't be. I am an electrical engineer (with a genius level IQ (yes, and some 'people skills' issues as well)) who has designed automotive electronics and has a European patent pending on this technique applied to NOT lighting......so trust me when I know exactly what went wrong in the design assumption phase at PAG and subsequent design and fabrication at Westfalia.
Now, if you will all excuse me, it's time to mix up a batch of Purplesaurus Rex, the OFFICIAL drink of the Rennlist DE forum, and try very hard to forget that I actually own this vehicle.
Best of luck with your decision.
#33
Moderator !x4
Now that you mention it, weren't we promised a new High Power (300mW) control unit.
I bet the 06's have it ! time to take the !!!!!! to town again I think !
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#34
Hey, what did happen to that new control unit?
Wish me luck guys, that drawing for a chance to purchase the PCA Porsche is just 1 day and a wake up away...
Was towing the trailer today getting it ready for a trip this weekend... Boy, I need a double...
That's better... So yes, she did a great job towing the trailer, just wish that damn "!" would go away...
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
#35
Hey Chris long time no hear !
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Hope all is well with you !
#36
Originally Posted by ltc
Be afraid, be VERY afraid.
Just a thought, does anyone know if the Toureg has the same issues?
#37
Official Wednesday AM Red Bull F1 test driver
New control unit coming????? Sure hope so. I guess I'm lucky to only have the ! all the time. It could be a DIASTER if it went out along with all the lights on the trailer on a long tow home at NIGHT!!
As for the Toureg, almost bought one. Would assume they have the same problems if it's a Westfalia unit in it too, which I also assume is the case...
#38
Lewis,
Since you live in Mass, go to Herb Chambers, the dealership the the Boston area.
I had the same problem, like everyone else. Then the service manager (Rayan) installed this new update for me. Since then the car throttle has been excelent and the problem went away.
Good luck
Good luck
#39
#40
Unfortunately this is an inherant issue. We don't all get the opportunity to thrash the living daylights out of the tranny to make its shift patterns better.
What I have found though is with enough complaining about the issue they will change the transmission control unit. The throttle adaption does change the way it drives and does get rid of driver history but because of its memory function and our driving conditions it adapts to a standard of running.
When the transmission control unit is changed they replace it with a later model 2005 unit which thinks and changes alot faster. You will also find its drive downshift patterns are alot quicker too. So whinge a bit more and you will reap the benefits.
#44
What build date on 05's got the latest update?? I had my 05 in a couple of weeks ago for 20K service and complained about hesitation and was told I had all of the updates :-(
ps Lewis,
could you please redirect your efforts to hesitation and not the blasted trailer lights! :-)
ps Lewis,
